1983 2 door brougham 4.1L V8 coolant flush
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 1983 2 door brougham 4.1L V8 coolant flush in Past Cadillac Vehicle Discussion; My coolant was replaced about 2-3 years ago. Coolant is still green. Should I do a complete flush(which flush fluid ...
    caddy1983 is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Fleetwood brougham 2 door
    Oct 2009
    110
    My coolant was replaced about 2-3 years ago. Coolant is still green. Should I do a complete flush(which flush fluid name brand do you guys recommend)or just a drain and fill. If I do a drain and fill do I need to bleed the system? Should I use the coolant tabs (how many do I need and do I use these tabs when doing a drain and fill) from the dealer or should I use the brand(cant remember the name) that I can buy at autozone
    or any parts place. is there a write up om this flush?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 1983 2 door brougham 4.1L V8 coolant flush
    Flush is a gimmick 95 percent of the time if the vehicle has no problems and has been reasonably maintained. Use the coolant tabs from the dealershit it they still sell them.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    the dealership should be able to get you the ACDelco tabs (they're cheap).
    Just a drain and flush should be fine. It's good to do it at least every couple years with the HT-4100.
    Oct 2009
    110
    how many tabs do I need? how do i add them to my coolant? if i do the drain and fill, do i have to bleed the system?
    Jan 2011
    Southern Ontario
    934
    The system bleeds itself.
    You should add 1 tab for every 2 quarts of fresh fluid added to the radiator.
    You should fill the rad up (not right to the top, leave an inch or two), start the car with the rad cap off and wait for the thermostat to open. When the fluid starts circulating, crush up the tabs and start adding the powder to the flowing coolant. Top the rad off and check the coolant level after it has completely warmed up.
  8. Remove Advertisements
