79 deville 425 coolant capacity??
Results 1 to 10 of 10
1985-1996 Fleetwood and Brougham Forum Discussion, 79 deville 425 coolant capacity?? in Past Cadillac Vehicle Discussion; Anyone knows how many QTs of coolant it takes on a 425? Thanks in advance!...
    vicello93's Avatar
    vicello93 is offline Cadillac Owners Fanatic
    Automobile(s): 1979 sedan deville
    Apr 2013
    107
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Re: 79 deville 425 coolant capacity??
    It should say in your owner's manual if you have it. Towards the back
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    Service manual says 19.8 quarts, so that's about 5 gallons. Make sure if you're not getting premixed, to use distilled water!
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    Distilled water?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes. No minerals to cause corrosion. Plus, you'll only need to buy half the coolant.
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    I have always used water from the garden hose or from inside the house and never had any issues. I usually buy the full strength and then just add water to it
    vicello93's Avatar
    Apr 2013
    107
    Yeah I alway bought the 50/50 mix actually thanks a lot for the info!
    Feb 2011
    30
    374
    Quote Originally Posted by 1980coupe View Post
    Not good at all! It sucks replacing freeze plugs, and regular water will corrode them. Plus you can get distilled water at the store for around a dollar. There is really no good reason at all to use regular water.
    vicello93's Avatar
    Apr 2013
    107
    So I changed the radiator, thermostat and gasket, all went good! Just the thermostat housing back bolt that was a pain to get it out and in but I got it. Thanks for the info!
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    There may be something to using distilled water but the whole entire planet used tap water mixed with antifreeze for many years.
    Dissimilar metals pretty much ensure something is going to corrode over time.
    I used to use 3 gallons antifreeze and top off with water on these cars.
  13. Remove Advertisements
