help w.th 93 fleetwood security
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, help w.th 93 fleetwood security in Past Cadillac Vehicle Discussion; i got tossed in a pool and now my key fob won't work so i can't turn off my security. ...
    mygpascaddy is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Fleetwood Brougham
    Aug 2012
    Arizona
    24
    59
    i got tossed in a pool and now my key fob won't work so i can't turn off my security. what can i do please help and the car won't turn over. i just want to drive home
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,956
    Re: help w.th 93 fleetwood security
    Try disconnecting the battery.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    Try unlocking the drivers door with the key and trying again.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Place the key fob in rice...it works seriously. A lot of people I know do this when their cell phones get wet and after a while, phone will work..
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Some security systems have a toggle switch with the key on the on position you should be able to toggle the switch. and disable the alarm system.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    It won't have that if it's the factory alarm he's having problems with.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,187
    If the 93 is the same as the 94-95, this is what you can do.. Open the glove box.. On the left side there is a string line that dampers the opening and closing of the glove box. I take a hook pick and pull the loop off the pin. Don't worry it goes back on easy. Now open and pry down on the center to get it by the latch so that it swings all the way open... Now look inside all the way to the left and you will see a relay held on by one screw.. Take out the screw and unplug the relay.. Now if you look at the relay pin out on the relay it shows two pins are the coil and two pins are the connection points.. Put a jumper on the two pins to complete the connection , now it will start...
  10. Remove Advertisements
