Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: 84 Fleetwood driveline vibration
    Sep 2004
    51
    so, when I let off the throttle at 55mph or higher, i get a vibration. car drives pretty smooth otherwise, driveshaft is perfectly balanced by a reputable shop, u joints are good and mounting is all good. the car is lowered, and my pinion angle has been adjusted to match the transmission angle (both are at 2 degrees opposing each other). any ideas?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Rear ends will vibrate when they are getting loose and worn out.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    Re: 84 Fleetwood driveline vibration
    Since you say that everything else is good, I'll guess pinion bearing in the rear end.
  5. #4
    Cadillac Giovanni's Avatar
    Cadillac Giovanni is offline Cadillac Owners Enthusiast
    Automobile(s): 86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
    May 2006
    Westport, MA
    31
    912
    Yeah, my '89 did this a few weeks before the diff gave out. I had a whole new rear axle from a mint donor car, so I just drove it 'til it died.
  6. #5
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Sometimes the rear brakes will even vibrate a bit when axle bearings are ready to puke oil.
    Load sensitive like described usually points to driveline but slack side of fan belts fwapping around or even a worn out radiator fan clutch can vibrate in a way that fools.....
    Another strange one is aftermarket exhaust or exhaust system missing mountings.
  7. #6
    Sep 2004
    51
    hmmmm, looks like I'm gunna havta take a look at the diff, i suppose. doubt its gunna be anything to do with the belt drive system cuz its all new. replaced everything new when I put the engine into it (350 out of an iroc z LOL) I know my exhaust is resting against the trans cross member, but thats a totally different noise. I'm putting the car on the lift tomorrow morning at work to do some work to it, will post what I find! Thanks for the replies so far!
  8. #7
    Jan 2008
    Minneapolis
    5,618
    What year iroc did the motor come out of?
  9. #8
    Sep 2004
    51
    bout an 88 or 89
  10. #9
    Jan 2008
    Minneapolis
    5,618
    Nice. That would make it an LT1, right? Nice. You document the swap on the internet anywhere?
  11. #10
    Sep 2004
    51
    no unfortunately its not the lt1. but soon I will be bolting vortec heads onto it, give her that extra lil kick in the pants haha. unfortunately I havent had time to put any of the pics or story online yet.
  12. #11
    Sep 2006
    Ontario, Canada
    44
    7,985
    I would bet anything that your vibration is caused by the exhaust hitting the crossmember. On my 94 Caprice wagon, the left over the axle pipe is a little too far forward. It touches the rear end. I chased a strange vibe on this car for ages. Three sets of wheels, lots of tires, two sets of shocks, full front end, all brakes. I finally figured it out.
    93 was the first year for the LT1 in the F body. If its a TPI motor, it's an L98. Some IROCs of that era were just TBI LG4s, though. Like an LO3/LO5, just less power/torque (hard to believe that is possible)
  13. #12
    Jan 2008
    Minneapolis
    5,618
    You're right Jay, thats actually what I meant, tuned port. I had a 92 bird, my first real baby. One day I'll get another.
  14. #13
    Sep 2004
    51
    ya it was a tpi 350. running tbi now tho. i had the car on the lift today and the pipes are definitely not touching. double checked the driveline angles, went after the pinion, tire balance. was thinking maybe pinion adjustment but normally its followed with a gear whine, so I'm kinda really stumped, but the thing is so annoying to drive on the hiway. thinking on hooking up a switch for the air ride, and run it with no air and see what the vibe is like, and then start increasing the height gradually just to see if its a pinion angle thing still. rather doubt it cuz i got that dialed in pretty good, 3 degrees up on the pinion, and 3 degrees down on the transmission.
  15. #14
    Sep 2004
    51
    well, diff checks out ok, tire balance was ok, driveline angles are 2 1/2 to 3 degrees. over 55 it starts vibrating bad, and when I let off the throttle it has a real good shake to it until i put my foot on the throttle a little, then it mostly goes away.thinking possibly pinion angle is too high? gotta get it back in the air when i get a chance to measure the u joint working angle. just about ready to light a match under her lol........
  16. #15
    Jan 2008
    Minneapolis
    5,618
    You measuring the drive train angle in the air?
  • You may not post replies
