spindle nut 1990 brougham - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
1985-1996 Fleetwood and Brougham Forum Discussion, spindle nut 1990 brougham in Past Cadillac Vehicle Discussion; Bleed is happening tomorrow. Next stop is my rear shocks. I'm starting a new thread on those, where I'm sure ...
  1. #31
    Johnny Kaka is offline Cadillac Owners Member
    Automobile(s): 1990 Brougham
    Sep 2012
    71
    Re: spindle nut 1990 brougham
    Bleed is happening tomorrow. Next stop is my rear shocks. I'm starting a new thread on those, where I'm sure to make a fool of myself all over again.
  2. #32
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    Quote Originally Posted by Johnny Kaka View Post
    Is it as simple as running a tube to an oil pan, opening the Bleeder valve, having someone press the brake pedal all the way in, and closing the valve while the pedal is still in? what could I do to screw up a bleed?
    That is correct. Brake fluid doesnt always cooperate but its that simple. Like outsider said, keep fluid in the res cause if you run out, you'll be in for a lot longer job then should be.
  3. Remove Advertisements
