My friends '89 Cadillac Brougham d'Elegance blower won't blow?
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, My friends '89 Cadillac Brougham d'Elegance blower won't blow? in Past Cadillac Vehicle Discussion; Compressor good, new blower motor, fuses good, just no power to the fan. What gives?...
    CandyLacBrome's Avatar
    CandyLacBrome is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Brougham
    Apr 2013
    Kuwait
    20
    7
    UnhappyMy friends '89 Cadillac Brougham d'Elegance blower won't blow?
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by CandyLacBrome
    I'd guess bad ground, bad fan speed module, or bad ECC head (in that order).
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Re: My friends '89 Cadillac Brougham d'Elegance blower won't blow?
    The Tan wire feeding the blower should be hot at all times. Check to make sure it's getting voltage.
    If it is, then you can run a wire from the from the blower motor case to a good ground and double check the motor starts to turn (be warned that it will spark since the blower is getting 12V already.
    If the motor starts, then the resistor module is highly suspect (The unit mounted in the air plenum directly beside the blower motor). It should be grounded to the center of the firewall.
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    There is also a fusible link in the blower feed.
    Apr 2013
    Kuwait
    20
    7
    Thanks for replying guys, I'm going to let my friend know.
  8. Remove Advertisements
