91 Brougham - Unable to open Trunk
Results 1 to 9 of 9
Like Tree4Likes
  • 6 Post By csbuckn
  • 2 Post By Brougham_D'Elegance
1985-1996 Fleetwood and Brougham Forum Discussion, 91 Brougham - Unable to open Trunk in Past Cadillac Vehicle Discussion; Hi, I am new to the forum, I need your assistance please regarding my 1991 Cadillac Brougham. I am living ...
    Brougham_D'Elegance is offline Cadillac Owners Member
    Automobile(s): 1991 Brougham D'Elegance
    Feb 2013
    11
    Hi,
    I am living in Abu Dhabi, I bought my Cadillac from US and shipped it here, it is now in the sea port yard, they removed the 2 front wheels so it can fit in the 40" container along with other cars. Now that they want to take it out of the container they are not able to find the wheels.
    They suspect that the front wheels are located in the back trunk, unfortunately they are not able to open the trunk even though they have the keys.
    Please advise what can be the problem and how to fix it so we can open the trunk.
    Many thanks in advance
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Brougham_D'Elegance
    Hi,
    I'd try putting the ignition to run or accessory (don't have to turn on the engine) and try the trunk release button in the glovebox. If not, you'd have to remove the back seat and get into the trunk that way and see if you can pop the lock.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Maybe the tires are pressing up on the trunk and you need to press down on the trunk to get the pressure off the lock.
    Feb 2013
    11
    Re: 91 Brougham - Unable to open Trunk
    Quote Originally Posted by cadillac kevin View Post
    Thanks for your advice, I already told him to check the glove box for the power button.
    I will call him again and transfer exactly your advice.
    Dec 2010
    St. Louis, MO
    6,395
    I would try csbuckn's advice of pushing down on the trunk lid before I would try removing the back seat (that's something I would not let a shipper at the port try to do, as they would probably damage the back seat)
    Feb 2013
    11
    Quote Originally Posted by csbuckn View Post
    Thanks also for your advice, in case the battery is there and connected and in case the power button from the glove box compartment is not working while in ignition on or accessory, I will have to go myself on Monday and try your advice.
    You are absolutely right, I will try it myself even if I have to drive for 4 hours round trip...
    talismandave and talismandave like this.
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    Sometimes the lock cylinder will stick. Try spraying the key with wd-40, insert and remove it a coupe times, spray it with more wd-40. Fiddle with it a little bit, once the old sticky bits in the lock are free it should work like new. This worked on my 1991 Brougham I had.
    Feb 2013
    11
    Thanks all for your support, the trunk opened couple of days ago just when they plugged a temporary battery.
    Thanks again.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Did you find the front wheels?
  12. Remove Advertisements
