Caddy 4100 or th200 problems
Results 1 to 12 of 12
Like Tree1Likes
  • 2 Post By 007joe
1985-1996 Fleetwood and Brougham Forum Discussion, Caddy 4100 or th200 problems in Past Cadillac Vehicle Discussion; So I just bought a 1982 Coupe Deville with 71k , I've owned several coupes but only 1 other 4100 ...
    007joe is offline Cadillac Owners Member
    Automobile(s): 82 coupe deville, 91 fleetwood brougham
    May 2013
    5
    So I just bought a 1982 Coupe Deville with 71k , I've owned several coupes but only 1 other 4100 car. The car has been sitting a while and after a 20+ mile drive home I parked it, but not before it decided to mark its spot with a small puddle of tranny fluid and a chatter coming from somewhere around the tranny or rear of the motor. In 16 years playing with cars I have never heard this noise. It's hard to isolate it but it does seem to be from the front of tranny. Any ideas what this could be?
    Thanks in advance!
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: Caddy 4100 or th200 problems
    Does it sound like stones got into the torque converter area?? Or flywheel chatter??
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Could be someone didn't tighten the flexplate (flywheel) to crank fasteners properly. There's only like 2 and a half of them and they use TormentX heads.
    May 2013
    5
    Well thanks for the replies, on the way to the mechanic I lost first, so he cinfirmed the pump went and bye bye tranny!
    Thanks for the replies
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by 007joe
    Sorry to hear that. I guess you'll be putting in another trans?
    May 2013
    5
    I am trying to get a donor car to pull the engine and trans out of, this way I could avoid future 4100 problems... worst case, I will put another trans in, but would prefer to do a conversion now...
    The Ape Man and The Ape Man like this.
    Dec 2010
    St. Louis, MO
    6,395
    I'd go for a chevy 350/ LT1 or olds 350 for a good mix of power and performance.
    May 2013
    5
    looking for Olds 307 or 350, did one conversion before, but now I need one and there's none around
    May 2013
    5
    So, just I picked up a 307 and 200 out of a cutlass, no donor car but pretty complete set up and should be tackling it this weekend. I did one of these 15+ years ago, so hopefully its like riding a bike!
    rorschach is offline Cadillac Owners Member
    Automobile(s): 1985 Fleetwood de Elegance coupe
    May 2013
    3
    Would the a/c work, as well as all the other accessories/electronics, once the 307 is installed?
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by rorschach
    AC- you would need lines from an 86-89 brougham and an olds compressor
    Alternator you may be able to use 4100 one and swap the pulley.
    PS, water pump, etc are 307 specific
    If you get the complete computer, harness, etc. for the 307, your idiot lights should work. If you go non CCC carb, you will need to pull the check engine bulb (or just live with it like I do). You will also need to change the dizzy to a non CCC one (computer controls the advance IIRC)
    May 2013
    3
    Wow, thanks for kicking down the knowledge, brother. I appreciate it.
  15. Remove Advertisements
