1990-1992 Cadillac Brougham (Base) & Brougham D'Elegance 5.7L V8 & 5.0L V8
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, 1990-1992 Cadillac Brougham (Base) & Brougham D'Elegance 5.7L V8 & 5.0L V8 in Past Cadillac Vehicle Discussion; How many people on here own a 90' - 92' Cadillac Brougham 5.7L V8 ? How do you guys mechanically ...
    Cadillac_Owner1991 is offline Cadillac Owners Member
    Automobile(s): 3 Cadillac's
    May 2013
    Melbourne, Victoria, Australia
    22
    5
    Smile1990-1992 Cadillac Brougham (Base) & Brougham D'Elegance 5.7L V8 & 5.0L V8
    How do you guys mechanically look after them
    Fuel type, oil's, fluids, etc
    Comment below
    I use nothing but the very best
    Premium Unleaded, Penrite (Premium Australian Engine Oils), Penrite fluids, BOSCH Ir-Fusion spark plugs, BOSCH ignition leads, etc
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    I got a 90 brougham delegance with the 5.7.
    I don't drive the car too much but I still keep up with the maintenance.
    I was told by previous owner that he used synthetic engine oil so I kept with that (I did not want to switch back & forth).
    -Engine oil & filter change every 3 to 4 months. I usually use mobile 1, valvoline, or castryol. (I do my self)
    -Tranny fluid flush once a year (done by Cadillac dealer)
    -Coolant change every 2 years (I do this service)
    -spark plugs (ac delco rapid fire), distributor cap & rotor every 2 years (I do this one also)
    -engine air filter as needed
    -fuel injection service & fuel filter every 2 to 3 years(done by dealer)
    -brake fluid change once a year(done by dealer)
    I use 87 octane has for this car.
    I also do the same for my 85 fleetwood brougham with the 4100, except on that one I use conventional engine oil.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I have a 350 in my brougham....I just follow normal service intervals for fluid changes (and use regular oil not synthetic) and run regular fuel in it (premium won't really help it do anything better).
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: 1990-1992 Cadillac Brougham (Base) & Brougham D'Elegance 5.7L V8 & 5.0L V8
    This thread really needs some pictures
    "Premium" fuel is not "better" fuel. It is just different.
    Use the formulation that your car is designed to run on. In your case, 87 Octane.
  7. Remove Advertisements
