Your thoughts on this oil leak?
Results 1 to 10 of 10
1985-1996 Fleetwood and Brougham Forum Discussion, Your thoughts on this oil leak? in Past Cadillac Vehicle Discussion; Did an oil change on mom's 84 4100 today. Used my new tall funnel, so it holds about two liters. ...
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,895
    Did an oil change on mom's 84 4100 today. Used my new tall funnel, so it holds about two liters. Poured in half a jug, the funnel drains slowly, the opening is only the size of a dime. As the oil goes into the valve cover, fresh oil starts to dribble down the back of the block. Quickly. Makes a decent puddle. I pour the rest of the jug slowly, no more oil down the back. I am 100% certain the funnel was IN the hole in the valve cover. My theory is this: the top of the head had a lot of oil in it, the oil couldn't drain in the drainback holes quick enough, and the oil level came up to the level of the old dried out valve cover gasket. This caused the dribbling leak that stopped when the oil level on the top of the head. It doesn't dribble when running (I ran it for about 5 min after the change). I'll do valve cover gaskets tomorrow, but I'm always open to ideas.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Sounds right to me. Maybe put a little engine cleaner in it.
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Canada
    444
    Re: Your thoughts on this oil leak?
    Does your Mom's 4100 have those little rubber V gromets at the far ends of the valve cover gaskets?
    Sep 2006
    Ontario, Canada
    44
    7,895
    I have no idea, what are they? Pic?
    Sep 2011
    Canada
    444
    Quote Originally Posted by jayoldschool View Post
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    interesting...I'd say the valve cover gasket would be the first place to check also. Or maybe the oil drainback holes could be getting gunked up too?
    Sep 2006
    Ontario, Canada
    44
    7,895
    Hmm. The leak would have come right from that area of the V, I would say. I have never heard of those V gasket parts. Will they come with a valve cover set? I guess I'll find out. (Checked Rockauto, the V parts are included). I'll also be able to see them when I get the covers off. WTH are the for? More 4100 craziness.
    I'll clean out the drainback holes, too, but they're probably good. I change the oil on this thing once a year, and it's as clean coming out as going in. The cleanest oil of any car I work on. It was a GM replacement engine that went in at 55k, and the car now has 147k on it.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    The v seals the gap created by the intake, head, and valve cover. It's not just a single flat head surface for the valve cover to seal on - the cover seals against both the intake and the head. Remember, on these, the intake manifold extends under the valve cover. The pushrods even extend through it. It's not unlike GM's popular 60 degree V6...
    Sep 2006
    Ontario, Canada
    44
    7,895
    Makes sense. Any install advice? Glue the Vs in, glue the gasket to the cover, torque down?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    I'd clean the whole shebang with a good fast drying solvent then goober some RTV right where it leaks. Done. Saves peeling it open.
  13. Remove Advertisements
