Oil pressure switch and connector?
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Oil pressure switch and connector? in Past Cadillac Vehicle Discussion; 83 Deville 4.1? My oil pressure switch connector was not connected and the wires were wrapped around each other. I ...
    Rodney6661 is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Deville
    Jun 2011
    Birmingham,AL
    26
    83 Deville 4.1? My oil pressure switch connector was not connected and the wires were wrapped around each other. I think this was done to make the car think it was connected. Once i changed the switch and the connector the car has been acting up. The idle is up and down and it cuts off.
    Jun 2011
    Birmingham,AL
    26
    Re: Oil pressure switch and connector?
    Now it won't start at all!
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Replace the sender with a gauge to see the actual oil pressure. If the oil pressure is too low, the pressure switch turns off the fuel pump.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    Try disconnecting the battery?
  7. Remove Advertisements
