96 Fleetwood Brougham
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By MoistCabbage
1985-1996 Fleetwood and Brougham Forum Discussion, 96 Fleetwood Brougham in Past Cadillac Vehicle Discussion; Need help, factory sun roof has started leaking. What's the best way to fix problem?...
    KaddyDaddy is offline Cadillac Owners Member
    Automobile(s): 96 Cadillac Fleetwood Brougham
    Feb 2011
    3
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Clear the drains.
    Not sure where they exit on the Fleetwood, but the grommets at the end if the tubes is usually where all the debris is.
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    Re: 96 Fleetwood Brougham
    yep, clean the drains first of dirt buildup, we just run air through them if you have a compressor, if there clean and still leaking, replace the gasket
    Sep 2010
    East Boston MA.
    29
    26,325
    If you use compressed air, use LOW pressure.
    talismandave and talismandave like this.
  7. Remove Advertisements
