1983 cadillac Brougham 4.1L V8 engine mounts
Results 1 to 14 of 14
1985-1996 Fleetwood and Brougham Forum Discussion, 1983 cadillac Brougham 4.1L V8 engine mounts in Past Cadillac Vehicle Discussion; my car needs engine mounts. Do you guys recommend polyurathane or just regular mounts from autozone, pepboys........ Where can I ...
    caddy1983 is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Fleetwood brougham 2 door
    Oct 2009
    106
    Where can I purchase goos strong long lasting mounts. also how difficult is it to replace the mounts. any write ups out there. Thanks
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,606
    Re: 1983 cadillac Brougham 4.1L V8 engine mounts
    I would use the regular mounts. No write ups but its no fun, gotta get to the bolts from the hole in the side of the crossmember.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    What happened to the mounts? I've been abusing these for years and have not had a failure.
    Feb 2003
    california
    69
    6,613
    I would bet any rubber aftermarket mount would be stronger than any 4100 engine!!!
    Oct 2009
    106
    My motor mounts are OEM. They are 30 years old. My mechanic said one of the mounts will need to be replace. Luckily the other is still in good
    condition. I might just change both if I replace one. again any write ups and parts recommendation. I do prefer getting them from my local auto parts if thats o.k
    Feb 2005
    Southern NJ
    54
    2,096
    The frame side of the mount which contains the rubber is identical to 77 and up RWD Deville/Fleetwood.
    Unless there was an underhood fire I still find it difficult to believe anything would have failed.
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    719
    Oil leaking on the rubber tends to degrade it. Might be what the mechanic is talking about.
    Cheers.......R.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by Robin Banx View Post
    Cheers.......R.
    True but HT-4100s don't last long enough to develop oil leaks. They are also an exceptionally oil leak free design. Coolant is another story : (
    Oct 2009
    106
    I do have an oil leak and have 241,345 original miles. My car still runs and drives great. Just need to replace the mounts. Replaced tranny mount
    about a year ago for the first time as well. Need help here for a write up. Thanks
    Jan 2008
    Minneapolis
    5,606
    Cant believe I actually found a pic with an arrow. The arrow shows the hole I had to go through to reach the bolt. The yellow zipties are how I held the bolts up during the process.
    Oct 2009
    106
    thanks for the pic. How would this help me with removing my mounts. need steps if anyone has this info. for me. Thanks
    83 Fleetwood is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Fleetwood Brougham
    Dec 2011
    Maryland
    45
    45
    Quote Originally Posted by caddy1983 View Post
    glad to hear your engine is still running strong, gives me hope that mine with 30,000 original miles has a chance. Sorry I can't help with the motor mount question or pictures.
    Jan 2008
    Minneapolis
    5,606
    I dont think anybody has a write up. Basicly you take both motor mount bolts out and lift the motor with a jack or engine hoist and get the bolts out.
  16. #14
    Oct 2009
    106
    can anyone help me here. any local mechanic in the 90650 area
  17. Remove Advertisements
