Secondary lockout lever
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, Secondary lockout lever in Past Cadillac Vehicle Discussion; Hi guys I have a problem with my carburetor on my 1980 - FLEETWOOD 368 CU. When i buy my ...
    CORNE DE BRUME's Avatar
    CORNE DE BRUME is offline Cadillac Owners Member
    Automobile(s): 1980-FLEETWOOD BROUGHAM
    Aug 2012
    FRANCE
    55
    85
    Red faceSecondary lockout lever
    Hi guys
    When i buy my car, she have some problem, because she run fast any time . I think it's the carburetor. I buy a new carburetor (remanufactured) and put it on my car. I have the same problem. The engine start well and good, but run fast. I think it was the oil switch pressure (for the electric choke) and i change the oil switch. Same problem....... Last week, i turn on my car and look in the engine, he run well and slowly. I push the accelerator and he run fast, but when i loose the accelerator, the engine run fast again. I look the carburetor and i see the secondary lockout lever (left face of the carburetor). This lockout lever is up and the engine run fast...... when i push the lockout level with my finger, the engine run slowly and very well !!!!! Why ? I look on my old carburator that is the problem, but i can no find.
    Do you know what happen ?
    On this car the pressure oil switch have TWO plugs, but the plug have three hole. Is it normal ?? On this car, is it a two or a three plugs on the pressure oil switch ??
    Thank for your help and sorry for my english
    Didier
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,147
    Re: Secondary lockout lever
    I thought the secondaries are supposed to open only when at full (or nearly full) throttle. Maybe the throttle cable needs to be adjusted or the linkage is hanging up on something.
    Aug 2012
    FRANCE
    55
    85
    Hi Outsider,
    thank for your answers. I look the throttle cable and it's OK. When i turn on the engine, the throttle is blocked in slow position. If i push the throttle, he stay in médium position and the engine run fast. I push a small part near the secondary throttle (left) behing the choke, and the throttle go on the first position and the engine run slowly. Why this small part blocked the throttle in medium position ? To drive my car, i blocked this small part with a small cord, and it's ok, the engine run slowly when i stop on a red light ! Before, when i stop on a red light and if i put the gear on "park", the engine run fast. When i put the gearbox on "DRIVE" the car jump hard : (: (
  5. #4
    Sep 2009
    33
    4,147
    I believe that small part is a vacuum brake. You may need to replace that or check the lines going to it. Is there a vacuum line going into it?
    I don't recall if the secondaries are controlled by the vacuum brake or not, sorry.
  6. #5
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    This may help identify some terms.
    http://carburetor-manual.com/rochest...late-a-41.html
  7. Remove Advertisements
