78 Fleetwood Brougham..transmisson
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, 78 Fleetwood Brougham..transmisson in Past Cadillac Vehicle Discussion; Hello everyone, bare with me as this is my first post and I am not the best person to talk ...
    buchholzkatie is offline Cadillac Owners Member
    Automobile(s): 78 Fleetwood Brougham
    Apr 2013
    24
    Hello everyone, bare with me as this is my first post and I am not the best person to talk about cars. Yesterday my transmission died(basically I cannot move in any gear now) and I was just wondering what size tranny can go into my car? Thanks for any help you can give
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,899
    Re: 78 Fleetwood Brougham..transmisson
    First, check the fluid level in your trans. If it is low, it will not work.
    Your transmission is a BOP bolt pattern TH400.
    Apr 2013
    24
    We out fluid in it and it ran for a little bit and then completely stopped..thanks!!
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by buchholzkatie
    Did you go by the fill line when the engine was running or not?
    Also, is the fluid leaking out? (I'm guessing so if you had to add fluid).
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Try changing the filter too. This is another common problem. People change the fluids over the years but never the filter. The filter usually plugs up and can cause the same issues you are having. These transmissions are usually pretty bulletproof. The only weakspot is the later TH400's use plastic apply pistons instead of aluminum like the old ones and they can break. I would pull the pan try a new filter and new fluid. It's a cheap option to try before replacing the transmission. If the transmission ends up being bad you are better off having your existing one rebuilt verses swapping it out for a rebuild because most of the time the replacements do not have the right shift calibrations in the valvbody, do not have the correct governor for full throttle shift points, and also don't have the right speedo gears so your speedometer will be off. I know there area lot of bad transmission shops out there but i've had really good luck with cottman transmission they're nationwide and will rebuild your existing trans usually at a very reasonable price compared to most.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by jayoldschool View Post
    Short tail. And Cadillacs have extra stuff. I forget what though.
    Extra clutch pack or sumptin'.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    You have a short tail TH400 in it. You can put other trannies in but it will require a different driveshaft and moving the tranny mount. The link gives you info about tranny lengths and mount locations.
    http://www.maliburacing.com/auto_tranny_id.htm
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Where are you located? I wish people would add this info. If you were in my area, I could offer assistance. When these transmissions start to fail, they sometimes will respond once they reach operating temperatures. One of my trans will not react when cold. Once the fluid warms up the sticky valve / piston will allow the trans to operate. Reverse usually always activates, but to get first level, hold the brake and put the selector into reverse, hold for a minute, move selector to drive, hold for a minute, back to reverse, back to drive. Does the pump whine? Is there any indication that the clutch packs are engaging?
  11. Remove Advertisements
