Cd player wiring harness for a 96 - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
1985-1996 Fleetwood and Brougham Forum Discussion, Cd player wiring harness for a 96 in Past Cadillac Vehicle Discussion; Dang pics always a plus bro,...
  1. #16
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    Re: Cd player wiring harness for a 96
  2. #17
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Found the pics:
    This is the '96 radio. It mounts like the later model cars - with "ears" on the sides. I haven't had my '94 radio out, but my understanding is that it mounts on the top and bottom? That's what the installation kit shows, anyway.
    This is the plastic that gets cut out:
    Plastic hacked out:
    The only part of the kit I used was some bits of plastic to make "ears" on the new Pioneer head unit (AVH-3200DVD). It was tricky getting the depth right.
    All done:
  3. #18
    May 2011
    GEORGIA
    463
    GREAT VERY HELPFULL,SO THE BIG PLUG IS THE ONLY 1 THAT GETS USED,NOT THE SMALLER ONES THATS PICTURED ON THE BOTTOM SIDE
  5. #19
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    The big plug is the HVAC controls. The smaller ones are the radio. I made my own harness that plugs into those connectors by snipping the connector off of the stock radio.
  6. #20
    May 2011
    GEORGIA
    463
    So if i cut the harness are all the wires the same color as the cd player/double dins?
  7. #21
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    No, they're not the same color. I had also posted a mapping of the Caddy wire colors to the aftermarket radio wiring (which are standardized). I have it scribbled in my '96 factory service manual. I'll see if I can find it later.
  8. #22
    May 2011
    GEORGIA
    463
    OK KINDA FIGURED THAT,YEA PLEASE DO IF POSSIBLE
  9. #23
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Here's the deal. The wire colors coming from the harness are different than those coming from the radio. So when you cut the connector from the radio, you need to map the wires to your new radio's harness. When you cut the harness from the radio, leave enough slack so you can connect your aftermarket harness to it (like enough wire to solder or use butt connectors). In the pics below, the wire color I wrote in is the color on the factory radio's plug.
    Obviously you could see the mapping if you plugged the connector in, but I went through the trouble of writing it down so I could assemble a harness on a workbench rather than in the dash.
  10. #24
    May 2011
    GEORGIA
    463
    HEY THANKS YOU BEEN VERY HELPFULL BRO, WHEN IT COMES TO THAT TIME ILL SEE IF I WILL CUT THE HARNESS OR NOT DEPENDS IF I GET THE DOUBLE DIN FIRST,WELL I DO HAVE A REGULAR CD PLAYER I WONDER IF I SHOULD PRACTICE WITH THAT HMNNNN
  11. #25
    May 2011
    GEORGIA
    463
    i couldnt find myself cutting the harness just yet,can some 1 show me a link to the correct harness first, like on amazon.com etc
  12. #26
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by 85 FLEETWOOD COUPE View Post
    If I could find one, I'd have used it. You don't have to cut the harness in the car - you cut the one off the radio to make an "adapter". If it makes you feel better, try to find a '96 junkyard radio. The Cadillac radios are unique, though. I tried a harness from a '96 Caprice/Roadmaster and it was totally different.
    I'm sure an adapter exists - there has to be another GM car with the same arrangement. But, the real problem is that everyone shows the '93-96 Fleetwood radios as being the same. This is incorrect - the '96 is unique.
  13. #27
    May 2011
    GEORGIA
    463
    Yea its nuts,i got my whole system just sitting here but cant use it because the damn adapter lol
  14. #28
    diamondhill is offline Cadillac Owners Member
    Automobile(s): 1995 cadillac fleetwood brougham
    Oct 2010
    33
    13
    i just bought a 96 fleetwood and im wanting to install a aftermarket head unit also , im willing to cut into the factory radio harness, do you have pics of what it looks like conected to the aftermarket radio harness?
  15. #29
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by diamondhill View Post
    I don't, sorry. You don't have to cut the car's harness, you cut the plug off the "pigtail" on the stock radio. That plug plugs directly into the car's factory harness. You can use it to make an adapter using your new radio's harness.
  16. #30
    kyle_mac is offline Cadillac Owners Member
    Automobile(s): 1993 cadillac eldorado, 1977 cadillac coupe deville
    Nov 2013
    26
    1
    you wouldn't happen to have the description of the aftermarket wiring
  17. Remove Advertisements
