New 90 Brougham D'Elegance owner with questions
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, New 90 Brougham D'Elegance owner with questions in Past Cadillac Vehicle Discussion; This is my First Cadillac and first GM product ever owned. From what little research I've done, the car has ...
    bikertrash3531 is offline Cadillac Owners Member
    Automobile(s): 1990 Brougham D' Elegance
    Apr 2013
    south west Missouri
    38
    14
    This is my First Cadillac and first GM product ever owned. From what little research I've done, the car has the Chevy 5.7L 350cid V8 with a 4L60E Automatic.
    First thing is, my digital fuel gauge is not working. Where do I need to look for the problem and how available are the parts? Also, where can I find the bumper/ tail light filler pieces and the piece for the rear license plate/ fuel door? Everything else seems to work fine minus the factory CD player which will probably get an aftermarket unit soon enough. Lastly, where on the car can I find a code to tell me what gearing I have in the differential?
    Thanks in advance,
    BT
    Cadillac Giovanni's Avatar
    Cadillac Giovanni is offline Cadillac Owners Enthusiast
    Automobile(s): 86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
    May 2006
    Westport, MA
    30
    912
    Re: New 90 Brougham D'Elegance owner with questions
    Hey, welcome to the board!
    The fuel gauge problem is a toughie. Could be the sender or the wiring, but I've heard that the dashboards themselves are prone to failure. Is it just reading full all the time, or showing empty?
    I bought my replacement fillers from http://www.steelerubber.com/, and they're pretty good. They also have great quality weatherstripping if you ever need it.
    Not sure about the diff. Someone else probably knows for sure.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Cadillac Giovanni
    check the SPID on the right side of the trunk lid for the RPO for the rear end. GU_ is the rear end ratio while G80 is posi, IIRC
    Apr 2013
    south west Missouri
    38
    14
    Thanks for the quick replies! It looks as if the gauge is reading full at all times. Also thanks for the link on the fillers. I will post a pic of the gauge asap to confirm that it is reading full.
    BT
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,899
    Gas gauge is likely broken ground at the tank.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Check the wiring for the fuel guage from the sender. The digital dashes are prone to problems but usually if that was it the guage wouldn't light up at all or it light up different segments and flash around a bit. It's more common for the odometers to go out.
    There was no options when it came to gears it went by engine. 5.7 was the towing package so it's probably a 3.08.
  9. Remove Advertisements
