1994 Fleetwood rides like a tank.
Results 1 to 12 of 12
Like Tree1Likes
  • 2 Post By Benzilla
1985-1996 Fleetwood and Brougham Forum Discussion, 1994 Fleetwood rides like a tank. in Past Cadillac Vehicle Discussion; Hello all, I just bought a Fleetwood from a private seller in Phoenix with a mountain of paperwork to boot. ...
    theshowroomphx is offline Cadillac Owners Member
    Automobile(s): 1994 Fleetwood
    Apr 2013
    1
    Unhappy1994 Fleetwood rides like a tank.
    Hello all, I just bought a Fleetwood from a private seller in Phoenix with a mountain of paperwork to boot. I'm in love with this car, but I can't help but notice it's lost the "Cadillac Float" over its 95 thousand mile lifetime in a garaged environment. I've had it for two weeks and every little bump on Arizona's roads gets transmitted into the cabin, and if I wanted massaging seats, I would have bought an S-Class.
    Here are some things of note I'll throw out here to help solve this:
    The tires are just over a year old going by their DOT codes on the sidewall. The specific model is the Hankook Mileage Plus II with lots of tread left on them and inflated to the proper tire pressure. Looks like they're wearing evenly, too. It feels like the vibrations get transmitted through the tiresas I'm not getting any feedback at all from the steering wheel.
    Also the steering and wheel alignment doesn't seem to be affected, although it was seriously gusty today and I was fighting for control of the car on the I-10 for a few scary minutes.
    The front strut mounts are original don't look collapsed under the hood, and I don't see the front of the car bouncing more than once if I push down on it and let go.
    In short, this car doesn't dampen any road vibration at all since I've had it. My guess would be tire imbalance, but the car's age makes me think otherwise. It has sat in a garage infrequently, and I'm not sure how this could affect its ride. I would like some expert input on this issue.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Re: 1994 Fleetwood rides like a tank.
    It doesn't have struts, it has springs and shocks. It's likely due for new shocks. Tires out of balance will give you a constant shaking that increases in frequency with velocity.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Properly inflated to the sidewall PSI or the owners manual PSI?
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Canada
    444
    What jayoldschool said, start there.
    Cadillac Giovanni's Avatar
    Cadillac Giovanni is offline Cadillac Owners Enthusiast
    Automobile(s): 86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
    May 2006
    Westport, MA
    30
    912
    Check under the trunk lid and look at the RPO decal with all the equipment codes. See if you have an "FE1" or an "FE2". FE1 is "soft ride" and FE2 is "Performance and handling." I test drove an FE2 car once, and the difference was quite jarring after having driven an FE1.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    We replaced rear shocks and tie rods a few years ago and may be a coupe of front stuffs that I don't remember , it handled poorly and rode like crap on uneven roads , and bounced too much as well . Now , it rides and handles well .
    May 2006
    Westport, MA
    30
    912
    Quote Originally Posted by Cadillacboy View Post
    What was the solution? It just got better over time?
    Benzilla's Avatar
    Benzilla is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Phaeton Coupe, 1990 Brougham d'Elegance 5.7 liter
    Oct 2005
    Chattanooga, TN
    4,416
    I think CadillacBoy meant that replacing the parts he mentioned was the solution to his problem.
    My '79 has been very jarring recently as well, however I know the front shocks are ancient, and my front end is pushing 231k with no rebuild. Shocks make a huge difference!!! That's where I'd start.
    Cadillacboy and Cadillacboy like this.
    Dec 2003
    36
    4,388
    Thanks Benzilla , this is definitely what I meant in my earlier message . I must add bushings were also replaced and it has been riding well since then . Still, it can't beat a car with an Airmatic but that's a different matter lol
    May 2006
    Westport, MA
    30
    912
    Actually, let me also suggest checking tire pressures. Some people overfill tires to an insane amount. Had a friend who was riding around in a Subaru Forester with 60 psi in each tire. I actually just decided to check mine, and they were 5 lbs. over-inflated. I let out some air, and just that made a world of difference.
    Dec 2003
    36
    4,388
    60 psi ? lol
    I assume your friend have some Airbus tires in his Forester , please forgive my message I could not resist
    TopherS is online now Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (97K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    303
    I agree that it is likely the shocks. The shocks on the car may not be in bad shape or old, but they may be a different type.
    Years ago, I bought a 1985 Town Car that was immaculately maintained. The owner reported it had new shocks and tires on it. It rode so harshly. In looking at the shocks, they were a racing-type shock. I replaced those right away. The tires were a lower profile (but not very much so). I replaced those, as well. Made ALL the difference in the world...rode like a luxury car after that.
    And as mentioned above, check for "FE1" or "FE2" on your SPID label. I owned a '95 Roadmaster with FE2 suspension (part of a towing package) and I drove a friends '94 Roadmaster with FE1 (Soft Ride Suspension). Very different ride between FE1 and FE2.
    Hope this helps.
  15. Remove Advertisements
