right front turn signal not working
Results 1 to 14 of 14
Like Tree2Likes
  • 4 Post By cadillac kevin
1985-1996 Fleetwood and Brougham Forum Discussion, right front turn signal not working in Past Cadillac Vehicle Discussion; I have a problem with my 86 FWB. The right turn signal does not work (lights stay bright and don't ...
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I have a problem with my 86 FWB. The right turn signal does not work (lights stay bright and don't blink when you turn on the signal). The left side works fine.
    I tried the hazard switch, and the left side worked fine and the right rear worked fine, but the right front stayed constant bright. I tried replacing the turn signal bulb and even the running lights on the right front, but it still stays constantly bright when the signal is on. Does anyone have any ideas? I checked all the running and signal lights on the car, and they all work. I'm guessing maybe a bad socket or a bad ground (couldn't find the ground for the turn signal bulb on the right front)
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    The easy way out of this would be to get an electric flasher instead of a thermal one. For whatever reason, your blinker circuit is not heating up the thermal flasher enough for it to blink(break).
    Edit...is it just the front but the back blinks?
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    If the right side don't work front & back it's the flasher, easy fix.
    IF its only the front not working you may have other issues going on...
    Dec 2010
    St. Louis, MO
    6,395
    The right side doesn't work when it's on blinker.
    When it's on flasher, only the right front doesn't work.
    AElayyat's Avatar
    Feb 2004
    So. Cali
    35
    1,135
    Quote Originally Posted by cadillac kevin
    Got ya..I had a similar problem a while back with my 85, my issue was that the the turn signal bulb had a broken contact, changed the bulb & all was good again.
    I would also look at the wiring to make sure nothing is broken.
    Hopefully your issue is a simple fix.
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by AElayyat
    I thought it was the bulb, but I changed it for a new bulb and still have the same problem (wouldn't think a new bulb would be defective). According to the FSM, its either an open ground or the signal switch.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,896
    Re: right front turn signal not working
    Swap the bulbs side to side to completely rule the bulb out.
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by jayoldschool
    Will do (thankfully, I haven't replaced the rear fillers yet, so I can just reach in and get a bulb from the backside). IIRC, I didn't have a problem until I changed my front turn signal lenses from orange to clear (and the bulbs from clear to orange)
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    I had the same issue. It turned out to be a broken wire towards the back by the drivers side taillight (this problem was on the drivers side). I just wire nutted them together for the time being, and when I get time, I will solder them back together. The guy who had it before me spliced into the taillight harness for the trailer wires. lets just say, that it was not done properly.
    Jan 2008
    Minneapolis
    5,612
    I know some bulbs have a high and low side. Maybe its in backwards if its possible with that bulb. Usually noticeable by how one running light is brighter then the other.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Try an extra ground wire on that light. I had an issue once with a weak ground and now that blinker housing has 2 ground wires.
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by cadillac_al
    I don't even know where the factory ground is for that light. I'm guessing I should splice into it and run a wire to the core support or inner fenders?
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    The ground wires are tied into the harness and its bolted to the radiator support.
    Check to see if all the bulbs are the right numbered model for the application
    Also it could be your directional signal switch is going bad. Thats located on the steering column.
  16. #14
    Dec 2010
    St. Louis, MO
    6,395
    Figured I'd resolve this issue (in case anyone has the same problem). The bulb was in backwards. Glad it was a pretty quick and easy fix
  17. Remove Advertisements
