New mats and tire cover
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
1985-1996 Fleetwood and Brougham Forum Discussion, New mats and tire cover in Past Cadillac Vehicle Discussion; I was wondering if anyone knows of a source for interior mats for my brougham. My car is Corinthian blue. ...
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    I also need a spare tire cover but I can't use the original from 1986 as I put in a full size spare. I think a 77 spare tire cover should do nicely. The problem is I cannot find one. Anyone know of a source for these? Thanks!
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by jamespowers
    Is corinthian blue light blue or dark blue? I come across blue caddy floor mats every once in a while in the junkyard. FWD mats will work, but IIRC, you will have to cut a slit in the drivers mat so it goes around the pedal mount on the floor.
    As for the tire cover- maybe getting a second small spare cover and sewing the side panel onto your small spare tire cover?
    Mar 2013
    1,100
    Re: New mats and tire cover
    Quote Originally Posted by cadillac kevin View Post
    It is a dark blue. For some reason my driver's side one disappeared. I might as well get a set so they will all match. Let me know what you find.
    That would work if I had the original tire cover. The spare tire, hold down and cover were missing. I elected to go with a full size tire. I thought the jack and tire iron were missing too but when I replaced the tire, I lifted the forward trunk cardboard and found I still had the original one---never used. So I have a spare jack and jack handle but I will live. The junkyard I went to to get the tire had a 77 but the tire cover was missing--darn it!
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    1977 Cadillacs had the first year of the compact spare tire.
    This is a link to a thread from one of our sponsors on the forum for brand new floor mats.
    http://www.cadillacforums.com/forums...-cadillac.html
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,028
    Look for a cover from a 91-96 Caprice sedan. They came with full size spares. 93-96 Cadillac probably did, too, but I can't confirm.
    Poda is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Base, 94 Fleetwood Livery-no vinyl top in sight
    Jan 2012
    Toronto, ON
    40
    286
    My 94 Fleetwood has a full size spare mounted on an extra rim. As per on the owner's manual it was an option, but based on what I've seen so far it looks like you only got the compact spare if you deleted the full size on the option list. So most 93-96 Fleetwoods should have a full size. The cover is pretty generic in it's design, and should fit any full size spare no matter where it's mounted (trunk/wheel well, etc)
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,498
    A lot of the caprices I've seen that I bothered checking anyway just seemed to have the compact spare. Good to know some came with full, have to keep an eye out for a cover. ALtho Im happy with the little one, takes up less trunk space.
    Sep 2006
    Ontario, Canada
    44
    8,028
    I'll check my parts car trunk! The snow has melted. Finally!
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    Quote Originally Posted by brougham View Post
    You can only get two bodies in there with a full size spare when you can get three in there with a compact spare,,,
    Mar 2013
    1,100
    Quote Originally Posted by jayoldschool View Post
    Thanks for checking!
    Quote Originally Posted by Bro-Ham View Post
    The 77 in the junkyard had a full sized spare. I guess it was an option back then.
    Jan 2012
    Toronto, ON
    40
    286
    Quote Originally Posted by drmenard View Post
    6 bodies if you run run-flats and no spare at all
    oldcaddybuyer's Avatar
    oldcaddybuyer is offline Cadillac Owners Fanatic
    Automobile(s): 2011 STS | 2013 ATS (03 STS, 96 FWB)
    Jun 2012
    Frederick, Maryland
    377
    Both my Roadmasters had full size spares. They may fit as well.
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    49
    4,152
    Quote Originally Posted by jamespowers View Post
    I think folks eventually got rid of the compact spare and put in a full size spare back in the 70's. The original compact spares had to be inflated before using and weren't exactly user friendly.
  16. #14
    Mar 2013
    1,100
    I can see that happening. If my mother's 75 Eldorado hadn't come with a full sized spare then I could see my father junking the space saver crap. It has a full size spare in there and I think they made sure it did before they bought the car. lol
  17. #15
    Sep 2006
    Ontario, Canada
    44
    8,028
    Just checked my parts car, it has the cover for a compact spare. That will be going in my SS where I have a compact spare from an 80s Caprice!
  18. Remove Advertisements
