Help and/or advice needed for power lock/seats problem. Fuse has been replaced.
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By carnut
1985-1996 Fleetwood and Brougham Forum Discussion, Help and/or advice needed for power lock/seats problem. Fuse has been replaced. in Past Cadillac Vehicle Discussion; I had to remove the fuse to the power antenna because the motor wouldn't stop running. After that, the interior ...
    Regi Tucker's Avatar
    Regi Tucker is offline Cadillac Owners Member
    Automobile(s): 1989 Brougham D'elegance
    Feb 2013
    Beaumont, TX
    58
    I had to remove the fuse to the power antenna because the motor wouldn't stop running. After that, the interior lights, power seats and power locks wouldn't work. I replaced the 20 amp fuse. The interior lights now work but not the seats or locks. But when I press the lock button I can't hear a clicking noise around the area of the glove box. Any thoughts, guys?
    Feb 2003
    california
    69
    6,608
    Re: Help and/or advice needed for power lock/seats problem. Fuse has been replaced.
    Unplug the antenna motor underhood by the hood hinge rather than removing a fuse. The windows and seats are powered thru a circuit breaker not a fuse. Check the BODY fuse (yellow) 20 AMP for being blown. If blown, that will keep the power locks from working. A blown body fuse occurs usually from money or tin foil in a lighter socket or a spark from inserting/ removing a cell phone charger.
    Benzilla and Benzilla like this.
    Feb 2013
    Beaumont, TX
    58
    Thanks, I'll try that.
  5. #4
    Benzilla's Avatar
    Benzilla is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Phaeton Coupe, 1990 Brougham d'Elegance 5.7 liter
    Oct 2005
    Chattanooga, TN
    4,416
    It's fascinating that Regi replaced the body fuse, and now his interior lights are working, but his locks still are not. Aren't they on the same fuse in '89?
  6. Remove Advertisements
