Carburetor Questions
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Like Tree1Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Carburetor Questions in Past Cadillac Vehicle Discussion; Good people, I have recently installed a reman carb on my 89 Bro with the 307. The car runs well ...
    GeneLaw1 is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Coupe Deville, 1989 Brougham, 1984 Mercury Cougar,
    Sep 2009
    Atlanta, Georgia
    31
    201
    Good people,
    I have recently installed a reman carb on my 89 Bro with the 307. The car runs well but when I kick the choke off it a putters and dies. Any ideas? I've been working with adjusting what I believe to be the choke plate, a black circular thing in the side....also what I believed to be an idle speed screw in the front. Either way, I just need some assistance. I was able to drive last night with no problem really other than the engine light flickering in the interstate.....this morning, I started let it run, and tap the gas and it sputtered off. Haven't been able to get it started again, haven't tried too much though.
    Appreciate any advice....thanks!
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Carburetor Questions
    Check out this video, and the other vids by this guy. They will probably help you understand what the adjustments do.
    http://www.youtube.com/watch?v=yX_hCujFQ_I
    Benzilla and Benzilla like this.
    Sep 2009
    Atlanta, Georgia
    31
    201
    Quote Originally Posted by jayoldschool View Post
    So Jay after watching a couple of these, I wanted your opinion. Is it usual to have to adjust the mixture screws and idle speed screws after putting on a new carb?
    Sep 2006
    Ontario, Canada
    44
    7,931
    Yes, the carb is going to need to be set up when putting it on. A tach and a vacuum gauge are essential. The benefits will include smooth operation, more power, and better fuel consumption.
    Sep 2009
    Atlanta, Georgia
    31
    201
    O boy, I have none of that stuff, nor do I really know how to use them...guess it may be time to find a shop, I at least want to get it to where I can drive it to one. At hot idle sometimes it barely even runs. smh
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    When I got my new carb, all I did was slap it on and reconnected everything and it ran fine. I made no adjustments
    whatsoever and ran fine. Still runs good, even though I had the caddy sitting since October of last year..
    Good luck with your adjustments.
    Good to hear from you and that you're doing fine after what happen...
    Sep 2006
    Ontario, Canada
    44
    7,931
    Gene, do you have a Harbor Freight near you?
    Sep 2009
    Atlanta, Georgia
    31
    201
    Quote Originally Posted by 1980coupe View Post
    O yea man, Didnt miss a beat. But I had to get that Caddy out of there, it was running pretty bad on the old one...but it was running better than it is with the new one...ugh!
    Harbor Freight Tools? If so, then yes there are a number of those around Atlanta.
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    68
    412
    I've replaced a number of carburators with rebuilt units in my 64 years. I have never had to adjust them; there ready to go out of the box.
    Tom C.
    Sep 2006
    Ontario, Canada
    44
    7,931
    You never bothered to set idle speed, nor mixture? A carb will run (usually) out of the box, but it will be better if it is at least checked.
    Aug 2012
    68
    412
    I have not, if I remember correctly, there was always a note with the instructions, that no adjustments were necessary as they are factory set from the rebuilder. Now with everything FI, I can't remember the last time I bought one. It may be 25 years ago.
    Tom
    Sep 2009
    Atlanta, Georgia
    31
    201
    Maybe something happened during the installation of mine....vacuum leak perhaps?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Did you play with the adjustments showed in the video? If that one didn't do the trick I'll bet there are a lot of other videos explaining it around the net. It sounds like a choke adjustment is all it needs.
  16. #14
    Sep 2009
    Atlanta, Georgia
    31
    201
    Quote Originally Posted by cadillac_al View Post
    The idle screws I did play around with. I was attempting to play with the mixture screws but I didn't seem to have the proper tool to turn them.
  17. #15
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,613
    Can you see the fuel coming out the jets in a good streem?
  18. Remove Advertisements
