1989 Cadillac Brougham Knocking PLEASE HELP!!!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
1985-1996 Fleetwood and Brougham Forum Discussion, 1989 Cadillac Brougham Knocking PLEASE HELP!!! in Past Cadillac Vehicle Discussion; Ok. So last night I was on my way back to school when I got off the highway and came ...
    reelheavy is offline Cadillac Owners Fanatic
    Automobile(s): 1989 cadillac brougham
    Apr 2011
    maryland
    46
    130
    Ok. So last night I was on my way back to school when I got off the highway and came to a red light my caddys oil light came on and then the check engine light popped on. And as I would be sitting at the light the light would stay on but as I accelerated again, it would go off. So I got back to my dorm and I could not check the car out due to the lack of light. So I checked it out this morning. I check the oil, and it was full and all the other fluids were fine. So started the car up and it was like a ticking noise and I hit the gas slightly and the ticking got louder but then would eventually fade away. I drove the car around the block and the oil light never came on but the check engine light was on the whole time. The car seemed to be sluggish and lacking power. I did not try to give it to much gas, but it was not the same car I was driving last week.
    Last weekend I did a full tune up on the car and it was riding GREAT!!! until last night. I need some help trying to figure out what the problem is and whether it can be fixed, or should I start looking for another ride??? Please Help. My # is 240-431-3310 Thanks.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Re: 1989 Cadillac Brougham Knocking PLEASE HELP!!!
    Doesnt sound good. If you want to find out for sure, rent an oil pressure gauge and check the oil pressure. Oil light with a normal amount of oil usually means very thin oil or bad oil pump. When's the last time you changed the oil? Either way, I would change the oil just to make sure you do have the correct amount of oil in.
    Apr 2011
    maryland
    46
    130
    I changed to oil last Saturday.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,903
    My old 87 Caprice with the 307 started to dimly illuminate the oil light when it was hot at idle in drive. I used to always think that it was the engine wearing as it got older, and the mains opening up in clearance... UNTIL one of the members here talked about the exact same issue, and how he resolved it simply by putting in a fresh oil pump. Give it a shot.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I'd guess the oil pump went out.
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (97K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    304
    I get a similar problem when my oil level goes low...which it appears you've checked. As I come off of a freeway offramp, my oil light will go on. That issue always goes away on my car with topping off or changing the oil. I've never gotten the check engine light, though.
    Oddly enough, I had gotten my oil changed today and told my mechanic that I was having a similar problem as what you are experiencing...very, very heavy knocking and half-power under acceleration...but it was not consistent...seems to happen more after coming down from highway speeds...when back in in-town driving. The mechanic thought it could have something to do with the lock-up converter on my transmission. Not sure, though. But after the oil change, it went away???
    Since your check engine light has come on, your car my have set some trouble codes. It's worth having them read to see what's been set.
    Please post back with your findings...as I am having similar problems.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Do a compression test of your engine. If your timing gear has shed it's teeth, they could be caught in and blocking your oil pick-up screen. Your poor running engine suggests there is more going on than a pump problem.
    Is it a ticking or a rap? A ticking suggests a lifter problem. A rap = a connecting rod bearing may have spun. Pull one plug wire at a time and run the car. If the noise goes away after you have pulled the plug on whatever cylinder, it is a spun connecting rod on that cylinder. You can run the car like that for awhile, just don't push it. If it is a ticking and it doesn't go away, it is a lifter tick. This means there is lifter failure or insufficient oil getting to the lifter.
    Apr 2011
    maryland
    46
    130
    Ok. So my first step should be to get the oil changed. Is there any specific oil I should use because I don't know how many times the mileage has rolled over. It may be 140k or 240k miles on the car. Which weight of oil should I use?
    Jan 2008
    Minneapolis
    5,612
    What oil did you use last saturday?
    Apr 2011
    maryland
    46
    130
    5w-30 penzoil high mileage
    I was told to use 20w-50. This time.
    Sep 2011
    Portland, OR
    45
    304
    My mechanic has moved my car to 30W, even though I've only got 77K miles on mine. I've got a couple small leaks, so he suggested that 30W would slow it down.
    Sep 2006
    Ontario, Canada
    44
    7,903
    30W will only increase start up wear. It will flow poorly at cold temperatures. It is the same viscosity hot as 5W30. It won't leak any less with 30W. Get some proper multi-viscosity oil back in there ASAP.
    Apr 2011
    maryland
    46
    130
    Quote Originally Posted by jayoldschool View Post
    What do you mean by multi-viscosity oil?
  16. #14
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Oil that takes on the properties of different viscosity oils, depending on temperature. 5W-30, 10W-40...
  17. #15
    Apr 2011
    maryland
    46
    130
    Oh ok. So what would you recommend?
  18. Remove Advertisements
