1977 Coupe Deville Value? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Like Tree7Likes
1985-1996 Fleetwood and Brougham Forum Discussion, 1977 Coupe Deville Value? in Past Cadillac Vehicle Discussion; Originally Posted by 77CDV Where in CA is the car? If it's near enough, I'll scope it out for you. ...
  1. #16
    Cadillac Kid03's Avatar
    Cadillac Kid03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Cadillac Seville SLS
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Re: 1977 Coupe Deville Value?
    Quote Originally Posted by 77CDV View Post
    Hes in El Cajon 92020 so about 3 hours google map says.
  2. #17
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Hmm. Bit of a trek for me, but I know someone who's close. Let me work on it.
  3. #18
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Sounds good my friend thank you for the help
    Photos i hope these are good Sub let me know if these are fine.
  5. #19
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    The right side looks good. If the leather hasn't dried, you may find someone to re-stitch the seat. It is not the common Seamist Green. Possibly a Firemist Green. Whitewalls would make it better appearing. From those pics the body appears straight. There appears to be a bubble on the vinyl top below the rear window. Bubbles are a sign of rust. Press in on the bubbles and they will crunch the rust blister. Check the grain in the top for signs of cracking where water can seep in. In '77 they did not have the Landau tops. The vinyl was laid over the metal. The bumpers look like they might be straight. The rear bumpers in '77 were the only ones in that series ( '77 - '79 ) produced with indents for the reflectors set between the rub strips. The steering wheel cover suggests the wheel has cracked, common for these cars. The dash pad ( crash pad ) has a propensity to crack near the middle along the air vent opening to the front and back. Dashes Only can do a better repair than upholstery shops can because they use a vacuum draw process to stretch the material over the dash foam. Just some observations from the pics provided.
  6. #20
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Quote Originally Posted by deVille33 View Post
    Wow thank you for the detailed observation and i'll take that into account but the seller is not wanting to go below $1350. You my Sir are a expert on these great cars.
  7. #21
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    It's color 94, Thyme Green Firemist. I can't see any bubble under the backlight, and it's really unusual for these cars to rust out unless the top has completely failed. From the little I can see, it's rough, but not beyond hope.
  8. #22
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    I don't think it's too bad, especially for the price. I'd buy it for 1350 (given it is in good shape mechanically)
  9. #23
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Here's the update on the coupe. Has 80K miles on it, Dash is cracked, steering wheel is cracked, fillers, needs a tune up, new front seats, top is faded, paint, headlight marker, rubber trim around headlight, dings. So is it still worth $1350?
  10. #24
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by Cadillac Kid03
    I'd try to get it for 900...all the minor cosmetics add up, and thats not an easy color to find interior parts for (I guess you could get ones in a different color and dye them though.) Engine tune up isn't that hard on the older cars (probably plugs, wires, hoses, and some carb cleaner or adjustment would get it running right.) Faded top doesn't really matter to me on a cheap caddy, but a failed top does (one just looks bad, the other will cause roof rust. 1350 is IMO about what the car is worth, but you can probably get it for cheaper.
    I'm guessing the car has 0 rust, right?
  11. #25
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Quote Originally Posted by cadillac kevin View Post
    Nope no rust other then where the undercoating got scratched up from the road real clean car, Hes not budging at all on this car but he will take $800 for a 77 Seville? I like the car but needs works. I'm gonna look for another one. Thanks for the help man
  12. #26
    Dec 2010
    St. Louis, MO
    6,397
    Whats wrong with the seville? Thats cheap for a great classic caddy.
  13. #27
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    Seville needs paint and other odds and ends like this one. He has tons of Cadillac's from all ages and they all need work exept a 98 Eldo. The Seville is nice too black with red leather!
  14. #28
    Dec 2010
    St. Louis, MO
    6,397
    I'd rock an 800 dollar first gen seville.
  15. #29
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    I'd pass on the Seville. They tend to have more electronics and they rust more easily.
  16. #30
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    My 78 Sevile has that magic factory undercoating that is tough as nails. If it isn't starting to rust yet then it won't as long as you keep it out of the salt. I love my old Seville and it handles like it's on rails, actually better than my 76 Camaro. 350 fi engine, th400 trans, limited slip rear, 4 wheel discs; what's not to love? I call mine my baby Caddy. It's a little cramped for room but that's how you get the good handling.
    http://m491.photobucket.com/albumvie...rsDpgkx5KNE%3D
    I don't know what is up with photobucket but I can't seem to link any photos. Maybe that link will show my babys.
    Bad to the bone:
    classic Caddy lines
    I would give a Seville in good condition a second look.
  17. Remove Advertisements
