Brougham rattle
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Brougham rattle in Past Cadillac Vehicle Discussion; 3E23K63He5Ia5O55F4d3j0d5b9d5af4ed1b97.jpg This is my new to me 1986 brougham. For what I got it for I won't complain but it ...
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Brougham rattle
    This is my new to me 1986 brougham. For what I got it for I won't complain but it has a few small things wrong with it. One of those being that there is a rattle like metal jingling at the front of the car when I go over bumps. Kind of strange and unsettling at times.
    Other than that the engine needs some tuning to run perfect but aside from tough cold starts and I can feel a little vibration like the idle is slightly off. I need to get the antenna working again as it is stuck extended. The passenger side door lock does not work from the driver side lock switch and the display on the radio is out.
    I guess minor things but we will see when I get into it.
    I am having that oxidized finish detailed too. That dull stuff doesn't work for me.
    talismandave and talismandave like this.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Brougham rattle
    Hard to tell from here but a few common causes are:
    Bad shock absorber upper bushings.
    Bad sway bar bushings.
    One very easy to check one is rubber hood depth stops. There are 2 up front and two under the cowl. They can dry out and make a really nasty noise on bumbs. A little white lube or even soap will make it stop.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Brougham rattle
    Broken sway bar end link. Easy to spot, easy to change, and cheap!
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by jayoldschool
    Thats what I was thinking, but when mine broke, it was more of a thunking than a jingling.
    Mar 2013
    1,100
    Re: Brougham rattle
    Quote Originally Posted by jayoldschool View Post
    I like cheap and easy fixes.
    Quote Originally Posted by The Ape Man View Post
    I will check all of those and see which one it is.
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Re: Brougham rattle
    Looks quite nice, the first thing I would spend money on is some whitewalls, it would really set off the dark color.
    Mar 2013
    1,100
    Re: Brougham rattle
    Quote Originally Posted by creeker View Post
    Well since they are nearly new Michelins, maybe I can just paint some on for now. I understand that you can grind back some of the black sidewall too but.......
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: Brougham rattle
    Grinding only works when you have white letter. We used to have a company when I sold cars that would grind a slot in the sidewall and then paint with a paint that worked on rubber. Don't know if anyone does that anymore?
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,164
    Re: Brougham rattle
    As already stated, my first check would be the sway bar links.
    Mar 2013
    1,100
    Re: Brougham rattle
    Quote Originally Posted by outsider View Post
    I have it in the shop with a laundry list of things to do to it but that rattle it at the top of the list. I'll let you know what is causing it when I find out and get the bill.
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,658
    Re: Brougham rattle
    Wheel cover rattle??
    Mar 2013
    1,100
    Re: Brougham rattle
    Quote Originally Posted by MrHolland View Post
    You know, you might just have something there. It does sound like the rattle I had when the wreath came loose from my 75 Eldorado. It sounded similar. Thanks for reminding me.
    Well, I got a few things sorted out already. The cold start problem was due to the carb idle. The door lock that wasn't working on the back passenger side needs a new locking mechanism. Still haven't gotten to the antenna or had it smogged yet. we will see what tomorrow brings.
    kntharty is offline Cadillac Owners Member
    Automobile(s): 93 Flleetwood
    Jul 2012
    32
    13
    Re: Brougham rattle
    Rattle could also be the heat shield on cat converter
  16. #14
    Mar 2013
    1,100
    Re: Brougham rattle
    Well, so far we also have found that the EGR valve needs replacing---big surprise. It may require a new cat but we shall see. It doesn't really have diminished performance. The antenna is getting replaced and the door lock actuator is being replaced. I am still not sure about the rattle though. Need to get it up on the rack and check it out.
  17. #15
    Mar 2013
    1,100
    Re: Brougham rattle
    Well, I got my car back Friday with all the fixes and it runs fairly well. Flying around town with it today. Friday I took it over to the detailer and they worked a fair amount of miracles. No more oxidation and it shines like glass. I just wonder how long it will stay that way.
    So anyway, I took the car over to AAA and got new plates for it and ownership transferred over to me. It took a while as the paperwork was kind of Byzantine but it is California so I expected it. Now on to just driving it and enjoying it.
  18. Remove Advertisements
