firewall holes?
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, firewall holes? in Past Cadillac Vehicle Discussion; I was wondering if anyone knew of any holes already in the firewall that I could pass a 0/1 gauge ...
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    firewall holes?
    I was wondering if anyone knew of any holes already in the firewall that I could pass a 0/1 gauge wire through (or maybe an existing hole that I could enlarge), preferably on the passengers side? I really don't want to punch a new hole if I don't have to.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: firewall holes?
    The radio antenna hole might be what you are looking for.
    What are you installing? Sounds like some heavy duty audio stuff at first guess.
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by The Ape Man
    Yup....running wire for a stereo system. 0/1 is oversized for what I'll be installing, but that way if I want to add anything, I won't have to run a new power line.
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    Re: firewall holes?
    I have run 0 gauge back and forth throughout my car (Which is a LOT harder in a Hearse, because there is no way around the partition) but of course, the front is the same. I agree. Try the antenna hole. If not, there is a hole for a vacuum line, up above the floor petals, beside the fuse box. I have MANY wires run through that on my car, of varying sizes up 0 gauge.
    My car probably has around 30 feet of 0 gauge in it, with the longest continuous piece being 14 feet. Hearses Rock.
    kntharty is offline Cadillac Owners Member
    Automobile(s): 93 Flleetwood
    Jul 2012
    32
    13
    Re: firewall holes?
    Another option is to put it in an wire loom and run it along the frame rail then you do not have to try and find a place in the carpet to hide that thick of wire, problem is you have to drill a hole in the trunk i did it this way and have not had any leaks.
  8. Remove Advertisements
