Results 1 to 9 of 9
Thread: Whats wrong with this picture,fuel line
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    Whats up guys well i put my 96 cadillac on jack stands to drop the gas tank to replace the whole sending unit in hopes to get her started for the first time but before i dropped the tank i peeked my head behind the tank to check on the lines for dry rot and i seen this the line to the left looked kind of funny,is there something that suppose to connect in the middle for that line to be hooked up as 1? or suppose to be 1 line?please help
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Its a vent line that goes to the charcoal canister but it wouldn't cause the car not to start. Mine is sitting the same way cause I dont have a charcoal canister. Just connect it when you put the new one in.
    May 2011
    GEORGIA
    463
    Re: Whats wrong with this picture,fuel line
    Yea im going to install a barb fitting
  5. #4
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by csbuckn
    Will not having a charcoal canister give you issues? Mine got pulled during the engine swap (still have it, but there is a battery where it used to sit)
  6. #5
    Jan 2008
    Minneapolis
    5,618
    Quote Originally Posted by cadillac kevin View Post
    No, I havent had mine for a couple years now. The canister was there to help use the extra fumes to give better emissions. I would pull the line off the gas tank so it doesnt vent through the line all the way in the engine bay and you wont smell so much gas under the hood. It really smells when you are racing or hard on the gas. You running two batteries?
    85 FC, that undercarriage looks super clean.
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,846
    Quote Originally Posted by csbuckn View Post
    The canister was there to help use the extra fumes to give better gas mileage.
    Ummm .......... NO ! The EVAP system (emissions mandated) uses gas tank vent line(s), solenoids, charcoal canister, and intake manifold vacuum to burn gas vapors stored in the canister during shut-down soak periods. After the engine warms up, goes to closed loop monitoring and the running conditions approach a steady highway speed, the system opens the charcoal canister to intake manifold vacuum to purge the canister of stored fuel vapor, thus burning it in the intake charge. Yes, it burns the vapor; no, it's not a gas mileage booster. Emissions only - and different engines/years use different versions of EVAP control.
  8. #7
    Jan 2008
    Minneapolis
    5,618
    Thats what I typed, emissions. Someone must have changed my post. Lol
  9. #8
    Dec 2010
    St. Louis, MO
    6,397
    I do not have dual batteries, but the alt on the 350 was on that side of the engine bay, so the battery got moved. The line was removed back to the fuel tank, I believe.
  10. #9
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    All Cadillacs should have at least seventeen batteries.
  • You may not post replies
