power seats
Results 1 to 11 of 11
1985-1996 Fleetwood and Brougham Forum Discussion, power seats in Past Cadillac Vehicle Discussion; how do i set the memory on the drivers seat...
    drahn is offline Cadillac Owners Member
    Automobile(s): 1993 cadillac fleetwood brougham
    Jan 2013
    power seats
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: power seats
    Did you get an owners manual with the car??? It will be in there.
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: power seats
    There should be a "set" button nearby, at least there is on all the Cadillacs i've seen. put everything where you want it, hold the set button, and press either 1 or 2 depending on which setting you want
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (97K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    309
    Re: power seats
    On mine, you move the seat to the desired position, press (don't hold) the "Set" button and then press the "1" or "2" button. Mine is a 1987...I don't know if it had changed by 1993...it's possible you may have to hold the "Set" button whilst pressing the "1" or "2" button. It's been a while, but I believe that I can do it without having the car "on". I do remember that the owners manual said that the car was to be "on", but I seem to recall doing it without the key in the ignition...I may be wrong, though. I do remember the manual said that the car must be in Park, however.
    My 2001 Park Avenue did not have a "Set" button...so you just moved everything into position and held the "Memory 1", "Memory 2" or "Exit" button for 3 seconds and it would beep. IIRC, you had to have the car "on", but not necessarily running...but had to be in Park. So if you don't have a "Set" button, you might try that.
    bornonthebayou's Avatar
    bornonthebayou is offline Cadillac Owners Member
    Automobile(s): 1988 Cadillac Brougham
    Apr 2011
    Florida Panhandle
    28
    46
    Re: power seats
    Wait, are you telling me these cars have a memory for setting the seat to a particular position?!? I just have refused to let anyone drive my car because it messes the seat up. Please don't my family and friends.
    No, in all seriousness, I had no idea this was possible. Going to have to go outside and check this out once this burn from the muffler stops hurting. (Got overeager to check something out).
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by bornonthebayou
    Depends if your car is equipped with it. If it is, you'll have a memory seats button (1, 2, and set) on the drivers door (if your car is from the 80s-92) or control panel on the seat (93-96)
    Apr 2011
    Florida Panhandle
    28
    46
    Re: power seats
    I have never looked down there. I will investigate! It wouldn't surprise. I am amazed by the attention to detail, but that's what was expected in a Cadillac.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: power seats
    I always used mine for "city" and "cruising" settings!
    Sep 2011
    Portland, OR
    45
    309
    Re: power seats
    Quote Originally Posted by talismandave View Post
    I'm 6'0" and my wife is 5'0"...so the memory feature would, theoretically, be a great feature in such a case. However, my wife won't drive the car ("it's too big") so I have #1 set as my driving position and #2 set as an exit position (all the way down/back).
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Re: power seats
    I've seen some 80s ones with it. TOo bad they didn't carry it over to the 90s.
    Apr 2011
    Florida Panhandle
    28
    46
    Re: power seats
    So I don't think my car has this feature.
    The seat buttons are on the armrest in the door, so I should have known.
  14. Remove Advertisements
