help/advice!
Results 1 to 14 of 14
Like Tree2Likes
  • 4 Post By Cadillacboy
1985-1996 Fleetwood and Brougham Forum Discussion, help/advice! in Past Cadillac Vehicle Discussion; 409112_10151144931002979_772723938_n (540x720).jpg Hey guys I own an 88 Brougham with the factory 307. It had been neglected when i bought ...
    C-Leb is offline Cadillac Owners Member
    Automobile(s): 88 Brougham
    Sep 2012
    30
    28
    help/advice!
    409112_10151144931002979_772723938_n (540x720).jpgHey guys I own an 88 Brougham with the factory 307. It had been neglected when i bought it and ive done my best to fix it up as much as possible. I am having a stupid heating problem http://www.cadillacforums.com/forums...l-problem.html
    But I have also had pretty heavy oil consumption... No leaks, no smoke out the back...? were talking at least 1 liter every fuel up.
    Also Its not everytime I drive but sometimes after its warmed up and I put it into drive my low oil pressure light will flicker. It goes off if in park or if i slightly 2 foot it. I did have the carb rebuilt by a guy i used to work with but i had to change jobs before we could do the initial setup on the car after the rebuild. I thought it might be some adjustments but this is the first carbureted car ive ever owned and im not sure what needs to be adjusted/ set up after a carb rebuild.
    Any help would be greatly appreciated as im tired of 2 footing and dumping oil in all the time.
    Caleb
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Re: help/advice!
    I had the exact same oil pressure symptoms on an old 87 Caprice with the 307. I always thought it was the bearing tolerances getting larger as the engine wore. However, one of our members had the same issue a couple of years ago, and he simply replaced the oil pump and it completely restored the pressure. The old pump was getting weak. As for the oil consumption, start with the basics. Check the PCV, the hoses, then start to suspect valve seals (would only smoke on start up), or rings, (would smoke all the time).
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    Re: help/advice!
    Sorry,my post is off topic but could not retain myself from posting because I like your photo shot and camera angle
    Sep 2012
    30
    28
    Re: help/advice!
    honestly after reading in other places i thought it might be the oil pump. just a pain since i already did the pan gasket with all the bs of unbolting motor mounts and jacking up the engine to get the pan out. dont want to do it again BLARG!!
    Thanks tho.
    As i Said before i know its not my valve seals my old dodge has that prob. Im not getting oil smoke anytime.... its weird i changed the pcv, what do you mean by hoses? I fixed all the leaks already
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: help/advice!
    Next oil change you could try using a heavier oil ...like a 20-50 and see if that changes consumption. Not a good idea in winter of course.No leaks at the rear seal??
    Sep 2012
    30
    28
    Re: help/advice!
    I may try this come springtime but its bloody cold here and my block heater is out of commish
    Dec 2003
    36
    4,388
    Re: help/advice!
    I used to have a Jaguar with bad valve seals as yours clad . Well, I tried a vast variety of oils from 10W60 to 20W50 . It kept popping out plume of blueish smoke when the engine was hot .I sold the car finally but for another reason .I asked my mechanic about fixing and he said it was not a big deal . He put motor additive , however, I don't remember what brand it was it seemed to cure the issue but it came back again
    Sep 2012
    30
    28
    Re: help/advice!
    Quote Originally Posted by jayoldschool View Post
    So its spring now and time to fix up anything that needs to be done to the regent.
    Im still have the oil pressure issue but i do have a small bottom end knock, might this be a bearing issue...? would it be main or rod bearings? ive never changed them with the engine till in the car any advice would be great! out of prudence i was planning on doing the oil pump at the same time.
    Also im guessing the knock would be a rod bearing....
    Cadillac Giovanni's Avatar
    Cadillac Giovanni is offline Cadillac Owners Enthusiast
    Automobile(s): 86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
    May 2006
    Westport, MA
    30
    912
    Re: help/advice!
    If you're going to try heavy oil, you could also try some lucasoil addative. Slowed the leak in my 307 considerably.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Re: help/advice!
    I did the rod bearings on a Crown Vic while the engine was still in the car. I wouldn't delay it if there's knocking, the longer it goes the more likely there'll be damage to the crank journals.
    I used plastigauge to check the bearing tolerances when I put the new bearings in. You already know how to take the pan off which is most of the job. Make sure to cover the new bearings in plenty of oil when installing them and keep them clean. I picked up new connecting rod cap bolts since I believe they are torque to yield and can't be reused. The Crown Vic had a cracked casting cap design which meant you had to be extra sure that you put the same cap back on the same rod and in the same orientation or else they wouldn't sit properly.
    Seville fan is offline Cadillac Owners Fanatic
    Automobile(s): 1986 Fleetwood Brougham
    Apr 2011
    Los Angeles, CA
    125
    Re: help/advice!
    Nice looking car. What kind of wheels are those?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Re: help/advice!
    The knock is probably the bearings from lack of oil pressure and if you're adding oil that often it's a burner. At this point it sounds like you're better off changing the engine then trying to repair it.
    Quote Originally Posted by Seville fan View Post
    THey look like factory wire wheels missing the center caps.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: help/advice!
    If it's really knocking, and not something else that sounds like a knock, then you are about done driving it. If it's a rod knocking then you won't get far with it now. If it were me i would either pull the engine and put a new crank, bearings, oil pump and timing chain; or start looking for a replacement engine. I happen to have a nice running 307 but it has been sitting for a few years. If you are in the northeast it could be an option since I travel south occasionally.
  16. #14
    Sep 2012
    30
    28
    Re: help/advice!
    Im only getting a small knock after its warmed up and at idle. not a rod knock noise (keeps knocking while revved up) which makes me think its one of my main bearings.
    Low oil pressure is only happening when im idling after warmed up. im assuming this all happened because the old couple i bought it off barely drove it and had it sitting for awhile. When I did the oil pan gasket there was sooo much sludge in the pan, guessing it restricted the oil pickup and starved one or more of my main bearings....
  17. Remove Advertisements
