1993 fleetwood brougham
Results 1 to 2 of 2
1985-1996 Fleetwood and Brougham Forum Discussion, 1993 fleetwood brougham in Past Cadillac Vehicle Discussion; my 93 brougham is leaking antifreeze between the head and intake manifold. could this be a bad manifold gasket? i ...
    drahn is offline Cadillac Owners Member
    Automobile(s): 1993 cadillac fleetwood brougham
    Jan 2013
    my 93 brougham is leaking antifreeze between the head and intake manifold. could this be a bad manifold gasket? i looked at the heater hose that comes out at the rear of the manifold its not leaking.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Re: 1993 fleetwood brougham
    Check the thermostat gasket first, but yes, it's likely one of the side intake gaskets. When you replace, just use a nice bead of silicone instead of the end gaskets.
