94 Fleetwood vinyl top reupholster?
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, 94 Fleetwood vinyl top reupholster? in Past Cadillac Vehicle Discussion; Like the title says, I have a 94 Fleetwood, and the vinyl top is getting jacked up from age or ...
    ail45 is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Fleetwood Brougham
    Aug 2011
    MIA
    27
    20
    Like the title says, I have a 94 Fleetwood, and the vinyl top is getting jacked up from age or whatever. I'm also in a shitty area now so no shops that are willing to reupholster it.
    I did a little research and found a link from a site that sells a new one fully made, but I still havnt tried or couldnt find how to actually remove the current top so wanted help on that. As well, I personally wanted to go with a different texture than the standard tuxedo texture, so how hard is to just reupholster the current one myself? Any help is highly appreciated.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,899
    Re: 94 Fleetwood vinyl top reupholster?
    To remove the top you simply cut and pull. You pop the side emblems off with a screwdriver or a trim removal tool. The trim below the back window at the edge of the top just pops off.
    You're in Miami, correct? There has to be a lot of shops in south Florida that can do a top. That place is the home of vinyl tops!
    If you want to do it yourself, you need to measure carefully and use lots of glue. It gets brushed along the edges and sprayed over the top. There's lots of videos on youtube (I searched "vinyl top install").
    http://www.youtube.com/watch?v=QLL99v6wa-k
    Aug 2011
    MIA
    27
    20
    Well I'm from Miami, but I'm stationed at Beaufort, sc. So closest thing would prob be Atlanta almost 5hrs away. But thx for the link, didnt consider YouTube since couldn't find stuff online. Ill check it out later, hopefully it's not too bad, if so prob gonna had to consider a top delete.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    From what I've heard, a top delete will be harder.
    mygpascaddy is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Fleetwood Brougham
    Aug 2012
    Arizona
    24
    59
    The top delete will be harder. Without the vinyl there's a whole different rear window trim which is hard to find along with you'll want to paint it and patch some holes as well.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Unless you car already looks like a pile I would rather pay someone to do it then try it myself. There's too much that can go wrong with vinyl roof installs.
    Aug 2011
    MIA
    27
    20
    Nah the car is looking good. The roof is one of the only issues I have. Ill try posting a pic up later. But yea I def don't feel comfortable doing the vinyl top myself after seeig that vid. Anyone know where I can get the weather stripping if I do a delete? Paint and body work shouldn't be an issue.
  10. Remove Advertisements
