ac comperessor bypass pulley
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree1Likes
1985-1996 Fleetwood and Brougham Forum Discussion, ac comperessor bypass pulley in Past Cadillac Vehicle Discussion; I have a 1978 Cadillac Coupe Deville with a 425 motor 4brl carb. My a/c clutch seized up, I charged ...
    cooper78 is offline Cadillac Owners Member
    Automobile(s): 1978 cadillac coupe deville
    Dec 2012
    grand rapids, Mi
    30
    1
    I have a 1978 Cadillac Coupe Deville with a 425 motor 4brl carb. My a/c clutch seized up, I charged the belt it started spinning then it'll stop, but after that behind the clutch the ac compressor started smoking. Original I was going to replace just the clutch then the compressor. Now I want to just delete the whole unit and get a bypass pulley bracket. Can anyone suggest a website to buy from and/or the type of pulley I need. Thanks Calvin
    Robin Banx's Avatar
    Robin Banx is online now Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    730
    Re: ac comperessor bypass pulley
    The cheapest way to fix it would be to get a good used pulley/clutch assembly for your existing compressor, install it and leave the wires disconnected so it can't be turned on. It should free-wheel forever.
    Cheers.....R.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    There is a belt you can buy. I have it on my caddy but its in storage. Ill see if I can find a part number. The belt would just go over to the power steering pulley, no need to run a delete pulley.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    csbuckn is correct.. Just get a short belt that goes from the crank to the power steering.. I would take a rope and run it around the two pulleys to get how long of belt you need .
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by drmenard View Post
    This works. I've done it.
    Ratcad78 is offline Cadillac Owners Member
    Automobile(s): 1978 Coupe Deville Presidential
    May 2013
    38
    5
    How does this work with a fuel line in the way?
    Jan 2008
    Minneapolis
    5,620
    It doesnt work. Move the line or dont do it. Belts and gas lines dont mix well.
    May 2013
    38
    5
    What is the best way to move it? Should I go to a braided line?
    Jan 2008
    Minneapolis
    5,620
    Yep, some type of flexable hose.
    May 2013
    38
    5
    Cool, thanks for the help
    Feb 2005
    Southern NJ
    54
    2,096
    I do not remember having to move the fuel line.
    Pretty sure the water pump pulley had to be moved to get the belt in place. It is very close to the crank pulley and the belt won"t squeak by.
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    I did this on my 78 fleetwood and didn't have to move a fuel line. Mine did not have the smog pump so if yours does it may be different. I used a shorter belt which just ran from the crank to the power steering pump bypassing the a/c compressor. You just adjust the tension of the belt at the power steering pump. The belt for the water pump usually runs from the water pump to the alternator to the crank and that one should not need to be changed. You may have to move it out of the way to change the belts but that would be it. Again this is for a Non-smog pump configuration. If yours used the smog pump it will most likely be different.
    May 2013
    38
    5
    I still have the smog pump and there is a steel fuel line right in the way from the crank to the water pump. I've looked at it every which way possible and the only solution I can come up with is to move the fuel line, maybe install a braided line so it frees up the space for the new belt. The steel fuel line is connected to a fuel filter located under the water pump.
  16. #14
    May 2013
    38
    5
    So I opted to change out the compressor clutch and I am feeling defeated at this point. I removed the old clutch and am trying really hard to install the new one but I can not get the second piece to slide into place. It is stuck about half way on the compressor shaft. It will not move anymore. I don't know if it's due to the heat and expansion but it just won't move. I even tried installing the front piece in hopes to be able to use the nut and tighten everything into place but I can not get the front piece to slide onto the shaft as well. I'm pretty stuck "literally" at this point. Any help would be greatly appreciated.
  17. #15
    mrmisanthropy is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    8
    I know this is an old thread, but I just did the bypass on my 78 fleetwood, and for the record, it's a 47.5 inch belt to go from the crank pulley to the power steering pulley . You could probably get away with a 47 incher too.
    Benzilla likes this.
  18. Remove Advertisements
