Frame interchangeability question??
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree1Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Frame interchangeability question?? in Past Cadillac Vehicle Discussion; Are all 1980 - 1985 Coupe Deville and Coupe Fleetwood frames interchangeable? Thanks for any input!!...
    Strickland is offline Cadillac Owners Member
    Automobile(s): None
    Dec 2012
    32
    71
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Strickland
    Yup....you can also use any RWD caddy frame from 1977-96.
    The-Dullahan and The-Dullahan like this.
    Automobile(s): None
    Dec 2012
    32
    71
    Re: Frame interchangeability question??
    And are the above mentioned frames the same as their 4 door counterparts?
  5. #4
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,881
    Yes, but there are minor differences for motor and trans mounts, braces, as well as for the later LT1 low AC compressor mounts.
  6. #5
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by jayoldschool
    True, but the mounts will swap across.
  7. #6
    Automobile(s): None
    Dec 2012
    32
    71
    So all 1980-1985 2 and 4 door devilles and fleetwood frames are the same?
  8. #7
    Dec 2010
    St. Louis, MO
    6,395
    Yes.
  9. #8
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,605
    Correct, all 80-85 2/4 door frames are the same. All frames from 77-96 are interchangeable with no mods. 86 and up will probably have motor mounts in a different location but you can unbolt them and move them to the right spot on most. But, to stay away from motor mount issues(cause they can be a pain), just stick with a frame from 77-85.
  10. #9
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by csbuckn
    The 86 and up frames still have the mount locations and proper mounting holes for the caddy engine mounts.
  11. #10
    Jan 2008
    Minneapolis
    5,605
    I would bet the up to 89 did but my 90 didnt have any extra holes. That was a pain that ended with my motor sitting a tiny bit crooked.
  12. #11
    Automobile(s): None
    Dec 2012
    32
    71
    I've read that the 80's frames were slightly heavier duty than the later 90's frames......true???
  13. #12
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,424
    I've never heard that. The 90-92 5.7L frames have reinforcements added to them that I'm guessing the 93-96s also had but don't know.
  14. #13
    Jan 2008
    Minneapolis
    5,605
    I've took apart a half dozen 80-92 caddys and they are the same that I can tell.
  15. #14
    caddy1983 is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Fleetwood brougham 2 door
    Oct 2009
    106
    after reading all this info., can I swap a 94-96 LT1 Fleetwood frame and use my 83 2 door Brougham body. If yes can I also use a
    94-96 LT1 roadmaster/caprice/impala ss as well. I was thinking of doing a 90-92 4 door brougham chassis/drivetrain swap and using my 83 2 door
    body. This is what members from layitlow.com do for conversions. I honestly love the LT1 drivetrain better. Why? I have a 96 Impala SS and love the performance. Can I use an LT1 chassis/drivetrain and use my 83 2 door brougham body?
  16. #15
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by caddy1983
    You will need a 94-96 fleetwood frame if you want the LT1. caprices/ impalas/roadmasters/wagon frames will not work (too short) but you could swap the engine/ trans and everything else you need onto your car.
  17. Remove Advertisements
