95 Fleetwood ABS/Traction control light
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
1985-1996 Fleetwood and Brougham Forum Discussion, 95 Fleetwood ABS/Traction control light in Past Cadillac Vehicle Discussion; I have a 1995 Fleetwood base, the traction control and ABS lights are on, sensor on one of the wheels ...
    Twelv-12e is offline Cadillac Owners Member
    Automobile(s): 95 Fleetwood, '04 DTS (for sale), '97 STS (for sale)
    Jul 2005
    raleigh, nc
    35
    18
    I have a 1995 Fleetwood base, the traction control and ABS lights are on, sensor on one of the wheels I'm guessing, since thats the only thing I can think of that would make both lights come on, other than the ABS module. The traction control doesnt work for sure, I'll spin out pretty easy on wet pavement. How to I figure out which one it is? I'd rather not replace all of them.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Refer to "Using the On-Board Diagnostics" in this link:
    http://myweb.accessus.net/~090/cfb-tech.html#diag
    Or go to a shop, and have your codes pulled.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    Re: 95 Fleetwood ABS/Traction control light
    you must have 04-31 or 04-33 codes... I have had them for more than a year, still cannot figure out... the warning lights will show in the morning and will go off if I restart the car.... then they may appear again in 10-15 miles...
    Jul 2005
    raleigh, nc
    35
    18
    Threw an 0427, Wheel speed sensor circuit continuity malfunction. Now what the hell does that mean?!
    Sep 2010
    East Boston MA.
    29
    26,325
    It means you have failed, front wheel speed sensor (or less likely, a connector/wiring problem). Not sure why it doesn't discriminate between right and left.
    Jul 2005
    raleigh, nc
    35
    18
    Any way to figure out which one it is?
    mutaal is offline Cadillac Owners Member
    Oct 2012
    3
    I had a similar problem in my '96 Fleetwood , and it turned out to be sulphate in the main ABS harness.
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by Twelv-12e
    Test them.
    c5cruiser's Avatar
    c5cruiser is offline Cadillac Owners Member
    Automobile(s): 95 Seville, 95 Fleetwood Brougham.
    Oct 2011
    Corona, CA
    95
    I also have a 95 Fleetwood Brougham. I've had the traction control light on for sometime now. I've replaced the sensors but the light stayed on so I've just dealt with it. Last night the ABS came on for about 5 minutes then when off. Reading the post it seems to be the same issue.
    What and how would I go and check the connectors/harness on this vehicle?
    Walk me through it please.
    Thanks for your input.
    c5cruiser's Avatar
    Oct 2011
    Corona, CA
    95
    FOUND IT!
    After putting it in the back burner I found the answer. Let me let you know what I found and how dumb it really was.
    I have a Corvette with a traction control on & off switch on the center console so I thought that the Cadillac would have the same. After looking through the owners manual I found that indeed there is one. I found it in the glove box. I turned it on and the problem was solved!
    It was that simple.
    Boy do I feel stupid by making a rookie move like that. I guess I just gave it too much thought and just went in circles. It wasn't until I forgot about it when the solution hit me.
    GEES!
    Now to find the alarm on this thing. I'm not sure it even had one but who knows what the previous owner did with it.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    lol.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    This must be one of the cheapest fix ever ,good to hear you found that glitch . I doubt aftermarket alarm gets alone well with the car though
    c5cruiser's Avatar
    Oct 2011
    Corona, CA
    95
    Quote Originally Posted by Cadillacboy View Post
    I'm reminded of my first car alarm. It tied into the door light switch, it had a hidden key switch to turn it on and off and the alarm was a bell.
    It worked great. Now if people would have done something when my car was broken into.
  16. #14
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    "Oh there is a car alarm going off, I better look to see if everything's OK!"....said nobody, ever!
  17. #15
    c5cruiser's Avatar
    Oct 2011
    Corona, CA
    95
    Quote Originally Posted by c5cruiser View Post
    I don't think anyone knew what it was since car alarms were not very common.
  18. Remove Advertisements
