87 Brougham front brake/bearings
Results 1 to 9 of 9
Like Tree1Likes
  • 2 Post By outsider
1985-1996 Fleetwood and Brougham Forum Discussion, 87 Brougham front brake/bearings in Past Cadillac Vehicle Discussion; Finally finished installing the new bearings, hub/rotors, calipers, and brake pads on my 87 brougham A few questions: I know ...
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,165
    A few questions:
    I know I have to bleed the front brakes now that I put new calipers on. Do I also have to do the rears? Or is that not necessary?
    I know there's no official "how tight" for the bearing nut but realistically how tight should it be? I've tightened them down finger tight. Is that good? Or should it be more than that?
    Thanks!
    mjs182004 and mjs182004 like this.
    Feb 2003
    california
    69
    6,666
    Re: 87 Brougham front brake/bearings
    You tighten the spindle nut till drag is felt on the rotor as you spin it. Then you back off one flat on the castellated nut and install the cotter pin. All this is done with the caliper not installed. Yes bleed all 4 starting with passenger rear then driver rear then right front then left front. That verifies NO air and no old fluid. Tightening the nut till drag is felt, centers the grease seal in the hub and allows some grease to extend from the bearing onto the race. How old are the flex hoses to the calipers? Did you lube the slide pins passing thru the calipers? Original flex hoses can delaminate internally and restrict fluid flow especially when you release the brakes. Alot of calipers are replaced simply because the hoses wont allow the caliper to release and people think the caliper is seized!
    Sep 2009
    33
    4,165
    The hoses looked good and felt fine and flexible.
    My calipers were functioning OK, but I replaced them anyways because they were very rusty and...why not replace them while I had them all disconnected anyways?
    It sounds to me like I tightened the nuts correctly for the bearings.
    I did lube up the pins. The brake pads I ordered actually contained a little packet of lube for them. I did read in the factor service manual that you can adjust the wheel bearing nut with the wheels on by removing the dust cap. Infact it said adjustment should be done that way if needed.
    When I turn the rotor, I do feel some drag. I'm guessing that is what I want? It shouldn't be too loose correct?
    Feb 2003
    california
    69
    6,666
    The hoses come apart internally (flake off rubber) . They can look great on the outside. You say you tightened them "finger tight" that's too loose. The adjustment done with the dust cap off is once the car's been driven and the calipers are fully retracted. As the rotor rotates as the car is driven, it pushes away the pad. My advice is from MANY years of experience. The money would have better spent on hoses, rather than calipers but I wont try to change your mind at this point. You asked how to do it right, I've told you.
    Sep 2009
    33
    4,165
    Thanks man. If the brakes feel like they're lacking flow I'll replace those hoses but I just bled them and they flowed fine.
    Feb 2003
    california
    69
    6,666
    The flow restriction is NOT to the caliper, but back to the master cylinder when you release the brakes. If the brakes get hot or dont release quickly suspect the hoses.
    Sep 2009
    33
    4,165
    test drove it just now and everything appears to be perfect. Car rolls straight, no excessive drag. no bearing noises, no wobble. Stops great, brakes release great.
    Thanks for your tips carnut, much appreciated.
    also, would restricted flow back to the master cylinder cause the brake peddle to not pull back up on it's own? because i'm still having that problem with my 69 lol
    Feb 2003
    california
    69
    6,666
    Nope! Could be push rod from the booster to pedal adjusted too short (rare) Return spring on pedal bracket weak/ missing. Misadjusted brake light switch. Binding pedal pivot up under dash. Worn bushings on cross shaft under dash where the pedal pivots.
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    Looks Good!
  12. Remove Advertisements
