Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 106 to 120 of 209
Thread: my 86 FWB 350 project ("hooptielac") thread
  1. #106
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Ran one of the RCA wires in my trunk (from left to right quarter panels.) Also started swapping my grille from '86 to '90 and changing the grille bezel from a ratty '87 to a nice '88. Then an unexpected rain storm came in and I got soaked. I'll finish the swap tomorrow.
  2. #107
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Re: my 86 FWB 350 project ("hooptielac") thread
    Quote Originally Posted by cadillac kevin View Post
    Ok, it is tomorrow. We need pictures.
  3. #108
    Dec 2010
    St. Louis, MO
    6,397
  4. #109
    Mar 2013
    1,100
    Not bad at all. It just needs that hood ornament to make it pop.
  5. #110
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    It is funny how much of a difference that makes! Really looks great.
  6. #111
    Dec 2010
    St. Louis, MO
    6,397
    Went to install my front fillers this morning. Found out my fenders have crusty rust from the brackets rubbing against the fender lip for 25 years and I have to reset my front bumper because it is off center quite a bit. On the plus side, my fillers perfectly match my car (except they're nice and shiny and my cars paint is ratty and not super shiny anymore)
  7. #112
    Mar 2013
    1,100
    Time to get out the rubbing compound and getting the rest of the car super shiny to match.
  8. #113
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by jamespowers
    Needs alot more than rubbing compound that paint is shot (the header and hood and trunk look bad because the paint has tons of crows feet in them).
    Besides, I'll be replacing the doors, trunk lid, and fenders (and hood if I can find one with no hail damage) with rust free straight ones (sure I could fix mine, but it's easier (and cheaper at $40 a pop) to buy new panels and get them repainted then to have to spend time grinding down the rust and beating out and filling the dents.
  9. #114
    Mar 2013
    1,100
    Ah, ok then. It is going to look a little wonky for a bit then.
  10. #115
    Dec 2010
    St. Louis, MO
    6,397
    I worked on my center console today....I notched the bottom for the seatbelts (pre-existing holes didn't line up) also decided that I'm gonna move the gauges up to the radio spot (got a 1.5 DIN radio bezel for it). I also cut the bottom for the seatbelt recievers....the precut holes were in the wrong spot by about 3 inches. I also am going to have to modify the rear panel of the console so that it sits properly on the trans hump
  11. #116
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Lookin real good. How wide and long is your center console?
  12. #117
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by csbuckn
    It's 10 inches wide. I'd have to measure the length (it's too long by about 1.5 inches though.
    I also cannot use the ashtray anymore....oh well, it's not like I smoke- and I'm putting a charger port in the console.
  13. #118
    Mar 2013
    1,100
    Looks like you are making progress there. Looking at the vent on the side of the console makes me wonder if it would be possible to use one of the original vents, like you have in the dash for that appliation. It would even allow you to shut it off. Just a thought.
  14. #119
    Dec 2010
    St. Louis, MO
    6,397
    I could shut them off (they are closable), but the defrost vents aren't connected to them (no tubing)
    And no, I cannot use one of the original vents. They aren't the same size.
  15. #120
    Dec 2010
    St. Louis, MO
    6,397
    took the plastic sleeves off of my seatbelts (and removed the middle seat belts)....no more interference with the console.
    Tonight, I'm making a panel to bolt under the rear deck that will hold the old school punch150 that will power the rear speakers and the crossover for the rear speakers/ subs.
  • You may not post replies
