my 86 FWB 350 project ("hooptielac") thread - Page 3
Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 31 to 45 of 209
Like Tree59Likes
1985-1996 Fleetwood and Brougham Forum Discussion, my 86 FWB 350 project ("hooptielac") thread in Past Cadillac Vehicle Discussion; I like that idea....
  1. #31
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    I like that idea.
  2. #32
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Re: my 86 FWB 350 project ("hooptielac") thread
    I figured it would be a lot cheaper to have them fit the skins to your seats than for them to start from scratch. Love the back seat!
  3. #33
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    I think that's a good idea.
  5. #34
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    not much progress, but its still progress
    got the front panel cut for the console....not perfect, but once its in, it won't be that noticeable)
  6. #35
    Dec 2010
    St. Louis, MO
    6,397
    got the crossmember notched today. It's not pretty but it is solid.
    also, I picked up a nice flexible set of window felts from the 86 d'elegance, a set of poverty hubcaps, and some klipsch bookshelf speakers from the back seat of a festiva in the junkyard(netted some nice woofers and horns from them)
    Benzilla and Benzilla like this.
  7. #36
    Jan 2008
    Minneapolis
    5,618
    Looking good, you'll be glad you did. From a distance, you can see my exhaust hanging down a little on the drivers side because I didnt notch it.
  8. #37
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    One of the best project threads i`ve read in a long time.Amazing amount of talent you have.
    Keep up the great work Kevin!
  9. #38
    Jun 2009
    29
    6,632
    Quote Originally Posted by csbuckn View Post
    Can't be worse than mine. The shop that did it (right when my car and I got to Florida and I had no clue of which shops were worth visiting) weren't the most competent. On the commercial chassis, there is a secondary beam that crosses over between the crossmember and the rear axle. This beam actually has a spot on EACH side for the exhaust to pass up and over it. However, they chose to go under it. WELL under it. Naturally, I have scraped that part of the exhaust on everything you can imagine (which is to be expected from Commercial Chassis cars anyhow, but really, this is just absurd)
    When I run my exhaust, I will do duals as well and naturally, tackle this obstacle the right way. Hoping I may have word on those motor mounts soon. I have a friend who saw some at his junkyard recently and plans to check back, in return for some of my spare pulleys, for his own Hearse.
  10. #39
    Dec 2010
    St. Louis, MO
    6,397
    Went to do the exhaust on my caddy today. Got all the parts and tools and whatnot....went to start it...nothing. battery was dead. So I went home, grabbed my jumper cables, and went back to start it. Fired right up for one second then flat out died. So I let it sit a couple minutes (charging) and tried again. It fired and ran, but ran like crap for 30 seconds. Put it in drive and it immediately died. Looked over at the fuel gauge and it was on E with the light on. It had half a tank in it last week. Someone siphoned my tank. They got 10 gallons of 2 year old fuel LOL.
    Also, on another note, my dad noticed my fan wasn't centered in the shroud. Its about 1 inch (guessing here) off center of the shroud and far too big for the shroud- it almost hits the upper radiator hose (its a freakin huge fan).
    I don't think the engine is off center because its perfectly level and I think there would have been issues with the trans not being centered on the hump or the driveshaft being off center. Looks like I may be going electric fans afterall.
  11. #40
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    725
    ^^GM mounted all the engines in their full-size RWD cars about 1" off centre to the right in the 80's. The trans is also off centre by the same amount. Look closely at your shroud and you will see the circle for the fan is also over to the right to compensate. Goodness knows what the engineering department was smoking back in the day.
    Cheers......R.
  12. #41
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,983
    Simple WAG, to eliminate driveline vibrations due to the offset of the rearend pinion?
  13. #42
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by Robin Banx
    Cheers......R.
    So its not just me? GM actually made them that way? How odd.
    I do need a smaller fan as the current fan is far too large (about an inch smaller than the circular part of the shroud itself).
    I wonder if a '93 350 fleetwood or roadmaster fan shroud would fit under my hood.
  14. #43
    Dec 2010
    St. Louis, MO
    6,397
    Make some progress last night.
    Cut a new panel for the console
    Cut a radio delete plate
    Also painted one of the speaker grates of my pioneer 6.5s to see how it looks.
    talismandave and talismandave like this.
  15. #44
    Dec 2010
    St. Louis, MO
    6,397
    I finished staining the new panels last night (need to get some more helmsman though...I'm really low)
    Also looking at these for the console lids.
    http://m.homedepot.com/p/Liberty-Geo...2-0/202023602/
  16. #45
    Mar 2012
    Madison WI
    58
    7,894
    Looks good. here are a few more to consider. The first two would leave the top flat so you wouldn't have to lean on it or catch sleeves on it.
    The last one would mount on the edge of the cover.
    http://www.ebay.com/itm/Cupboard-Con...item51a607e205
    http://www.ebay.com/itm/Concealed-Sc...item51a21ea343
    http://www.ebay.com/itm/Sugatsune-SN...item27cc42c1a9
  17. Remove Advertisements
