Page 12 of 14 FirstFirst ... 234567891011121314 LastLast
Results 166 to 180 of 209
Thread: my 86 FWB 350 project ("hooptielac") thread
  1. #166
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Re: my 86 FWB 350 project ("hooptielac") thread
    started working on the quarter panel today. Man is it an uneven mess! (as evidenced by the colors from sanding)
    you can see where they painted over the factory paint and where they used the cadmium primer
    behind the front rocker chrome clip....love the halfassed filler job
    look at that lovely masking job
    underside of the quarter.....not horrible, but needs to be sanded and repainted
  2. #167
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Quote Originally Posted by cadillac kevin View Post
    You need yourself a media blaster.
  3. #168
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by jamespowers View Post
    Rust isn't that bad....it's all surface rust.
  4. #169
    Robin Banx's Avatar
    Robin Banx is online now Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    725
    ^^ JP has the right idea. If you don't want the rust to come back, you must get rid of all of it. Sand or other media shot under air pressure is the only way.
    Cheers.............R.
  5. #170
    Mar 2013
    1,100
    Getting the surface completely clean can really only be done with blasting. It gets into the pits and crevices.
    Go buy one for the Olds.
  6. #171
    Dec 2010
    St. Louis, MO
    6,397
    But then half the toro would be gone
  7. #172
    Mar 2013
    1,100
    Then replace that half.
  8. #173
    Dec 2010
    St. Louis, MO
    6,397
    I'm getting a 68 for that (I'm gonna put the drivetrain, interior, and front and rear clips of the 66 on the 68.)
  9. #174
    Mar 2013
    1,100
    You are going to FrankenToro it together.
  10. #175
    Dec 2010
    St. Louis, MO
    6,397
    Went junkyarding. Brought back a 140 amp CS144 alt from a fauxpala. I figured for 25 bucks, it was worth it.
  11. #176
    Dec 2010
    St. Louis, MO
    6,397
    well, today I started out wanting to see if my new alternator would fit. So I popped the hood and removed the old one in under 5 minutes. while I have the alt off, I'll figure I'll decode the engine block and see if it was the original engine from that 87 chevy truck I got the engine from. Nope.....it is not a 1987 350....its either a 1975 350 from a conv cab or a 1978 350 from a 2500-3500 series bus. yay redneck engineering! it also has 3 coats of paint on it. original orange, a brighter orange, and black. looks like its been repainted a few times (and each time most of the paint was removed)
    So I go to install the CS144 and it will not clear the bracket (fan hits the bracket). I talked to my dad and suggested drilling the hole on the intake bigger and shimming it to swing it upwards. His reply is "just use a J bar and bend it upward. thats too complicated." Somehow I like his idea better LOL.
    So then I ended up trying to reinstall the original alternator, but the bolt that goes form the alt bracket through the alt to the block would not thread. pulled the bolt that holds the top alt bracket to the intake and threaded it in the hole and it stuck, then tried threading the super long bolt into the threads in the intact and it stuck....so not sure whats up with that, but I'll be buying a new long bolt tomorrow.
    This is how I left it tonight. I hate it when I cant get stuff done.
    Also worked on my console some more tonight. Got the hinge done for the "storage compartment" door
    still need to cut down the door as it is too long and hits the "radio"
    oh yeah, did I mention my fancy new delco radio. it doesnt work, but it looks like it does (well, once I get the volume/ tuning pots installed)
  12. #177
    Dec 2010
    St. Louis, MO
    6,397
    been working on the hooptielac the past few days
    cleaned up the engine bay wiring. now to just put a crinkle tube on the alt harness wires.
    ran a wire for the tach. Couldn't get a connector at the parts store, so I hit the junkyard
    tach wire is the green wire
    also picked up some other junk at the junkyard. A bunch of chrome, a factory garage door opener (!) and a radio from a olds 98 ELITE, Spent 15 bucks total. I am happy.
    also did some redneck soldering on the starter connection. Forget crimping with channellocks....solder works much better
    also picked up some SS springs, mcgard lugnuts, more wiring to rerun the batt to dist block connection, and some 0 gauge crimp terminals.
    Next week comes new springs, and a 0 gauge alt to battery wire.
  13. #178
    Dec 2010
    St. Louis, MO
    6,397
    went junkyarding again
    for 60 dollars, came back with a set of damn nice (one mint, one really good) toronado trofeo buckets (with lumbar pump/ harness) and a 9c1 caprice cluster
    I think I'm gonna need a new console as these seats are wider than the bravada ones.
  14. #179
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Very nice! They must be the Lazy Boy option, I see they have footrests!
  15. #180
    outsider is online now Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,192
    haha ^
    Nice scores. I wish the junkyards around here had good parts. all we seem to have are modern cars or gutted classics with nothing good left in them.
  • You may not post replies
