Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Oh wretched steering wheel
    leatherandwood's Avatar
    leatherandwood is offline Cadillac Owners Member
    Automobile(s): 79 deville
    Aug 2012
    St. Louis
    71
    So...
    Not the most savvy when it comes to automobiles, cutting my teeth on a good ol' 79 Deville. As we all have
    seen; the wheel cracks with age/abuse. Mine's not bad, but bad enough that I wanna fix it. Since it's telescoping, do I have to remove the steering column?
    How do I go about it with the least amount of damage and expletives?
    Or. Is there a place that refurbishes them without charging an arm and a leg?
    Or. Would I be better off using some matching filler?
    Any help on this project would be much appreciated.
    Brough is offline Cadillac Owners Member
    Automobile(s): 1988 Brougham
    Aug 2012
    Maine
    47
    80
    Re: Oh wretched steering wheel
    It's easy enough, take the horn button off, take the telescope lock lever off, wind out the telescope lock cam and shaft (lefty loosey), take the steering wheel retainer nut off.
    NOW it is best to have a puller, but I've taken many off with a good whack from a wooden mallet. (If you use a steel head hammer be sure to protect the threads and end of the mounting shaft somehow). Also be sure to pull the telescope out a bit so the moving part of the column is not bottomed out, you want the force to go into your other hand holding the wheel.
    ALSO DON'T REPEAT DON'T have your face too close because many many times when I was younger have I had a steering wheel crack the bridge of my nose! (Hurts like hell and may produce blood).
    Aug 2012
    St. Louis
    71
    Good to know! I've been scouring junkyards and cannot find a decent/matching one at all.
    Do you have any experience repairing older ones?
  5. #4
    Aug 2012
    Maine
    47
    80
    Nope. Is it a show-er or a driver? If it's a driver I'm sure there's somebody out there who can do something that looks nice or you can buy a stitch up cover. If you want it original go the junkyard route. Strange they don't seem to hold up well.
  6. #5
    Aug 2012
    St. Louis
    71
    Trying to get it show-y. Mostly wanna clean up the aesthetic defects so my lady and I have something nice to step out in. The morons that owned it before me just didn't give it the love it deserves.
  7. #6
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,981
    Use a steering wheel puller. For a non-leather wheel, you can file cracks, fill with epoxy, sand, prime, paint. I chose to replace mine with a good used leather wheel. There are companies out there that specialize in steering wheel restoration if you want to get spendy.
  8. #7
    Aug 2012
    St. Louis
    71
    That Craft Customs seems like a good candidate. How spendy is spendy? If it's over 200, I really don't wanna sink that much into it.
  9. #8
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Leather and wood- what color is your wheel?
  10. #9
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    CADforce69 did a whole write up about restoring his wheel in his thread about fixing up his 69 SDV. Look for it.
  11. #10
    Aug 2012
    St. Louis
    71
    Quote Originally Posted by cadillac kevin View Post
    It's a light beige (I think) whatever color they used to match the "Western Saddle" interior.
  12. #11
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    There are usually a few decent OEM steering wheels available on eBay.
    Otherwise, here are a couple of options:
    http://www.garyssteeringwheel.com/
    And this one was already mentioned, here is the link:
    http://www.american-stitches.com/
    As Craig will always say, look in Hemmings if you need more.
    You can always buy a leather steering wheel cover, I have done that on some hopeless steering wheels in the past, and it turns out pretty well if you are patient enough to stitch it up right.
    Good luck!
  13. #12
    talismandave's Avatar
    talismandave is online now Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    I have not finished mine yet but I pulled mine with 3 5/16 coarse bolts and a heavy chunk of steel.
    I then filled it with epoxy putty and sanded it down. Then painted it and cut and put in wood insert, stained and polyurethane then chrome pinstripe tape. I need to redo the stripe tape to get it straighter, then I plan to cover with the two part epoxy they use to cover coins on bar tops!
  14. #13
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    Mother of Gawd look at that thing. You do know Sears sells inexpensive pullers right????
    Eastwood's has a steering wheel DIY repair kit. http://www.eastwood.com/complete-ste...ation-kit.html
  15. #14
    Mar 2012
    Madison WI
    58
    7,894
    Quote Originally Posted by Dirtywaterdiver View Post
    Can't beat free!
  16. #15
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    That there is some serious craftsmanship, Dave!
  • You may not post replies
