New to caddys n forums - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 83
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, New to caddys n forums in Past Cadillac Vehicle Discussion; kinda sticks out this is the olds 307...
  1. #16
    Boufo is offline Cadillac Owners Member
    Automobile(s): 1989 fleetwood
    Jun 2011
    wakefield mass
    50
    74
    Re: New to caddys n forums
    kinda sticks out
  2. #17
    Jun 2011
    wakefield mass
    50
    74
  3. #18
    Jun 2011
    wakefield mass
    50
    74
    i have more
  5. #19
    Jun 2011
    wakefield mass
    50
    74
    i have more
  6. #20
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    That install looks nice. I bet it's a 1000% improvement over that 307 (bet it gets better mileage too). Also, I can't say I've seen many fwb's with clean undersides like that (then again, MO is part of the rust belt).
  7. #21
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    lol, we did ask for pics! To help others: the frame crossmember is notched for the AC compressor. It's mounted low on the LT1 B/D cars (and their frame is factory dimpled). What did you do for mounts, speedo, and AC function?
  8. #22
    Jun 2011
    wakefield mass
    50
    74
    i bought a/c hose for a impala ss i bent it to fit i have a fitting on order because the acummulator has differnt treads the speedo i order a little trick box that converts the speed sensor n has a cable that run the manual speedo cost is 325 plus shipping still waiting on it i also added a 3200 stall converter to help it launch. i am looking for a rear end from a limo i bought one for my friend the other day i need one more its a huge one 9.4 ring n pinion but comes with a posi n 3.73 gears i was lucky bought the car on ebay for 2G's n drove it back 1200 miles from Alabama to Boston it was slow my god hahahaha but now it flys. i haven't driven it too much until i put the speedo converter in because the trans thinks its in park.
  9. #23
    Jun 2011
    wakefield mass
    50
    74
    The motor mounts i used Impala SS ones n just welded them after i set the motor in place. i have more pics too but i will post later let u digest these first lol.
  10. #24
    Jun 2011
    wakefield mass
    50
    74
    i also had to make a new drive shaft because the old one was too short i got lucky found a drive shaft from a 67 Chevelle vert that was too long added u joints n shortend it i got the shaft for free thanks to my friend mike. cost 160 to shortend n balance n new u joints.
  11. #25
    Seville fan is offline Cadillac Owners Fanatic
    Automobile(s): 1986 Fleetwood Brougham
    Apr 2011
    Los Angeles, CA
    125
    Great looking car. Love the shots of the fins hanging out of the garage door. White Caddy + tinted glass + performance rims, there's nothing else like that around. With an engine to back it up. Sweet ride!
    How did you get the undercarriage so clean? Is that how it came from the factory or did you repaint? Is the factory all body color under there or is there some black detail paint too?
  12. #26
    Jun 2011
    wakefield mass
    50
    74
    its all body co;or i didnt repaint anything i just wiped the floors clean the car had never seen salt but i had to drive it back new years day i only painted the frame because it was getting surface rust from driving it in when i got home i took off the rear wheels n the center of the hub was still bear clean metal like the way it was built i cleaned the grease of the cross member in the engine bay that was clean rust free metal too the car is super clean i love it now with the motor trans tires n steering box its like a sports car i cant wait to add big sway bars to add more grip in the corners i will not change the springs or shocks they r in good shape n the car ride nice no float at all it does fry first n second gear with ease. i am happier than a pig in shit. i put it on my lift just to look at it under neath its so clean. i will be buying a 2 door when i find the right car n colors it has to be super clean that will get a LS swap. i will add to my stable of misfits i own
  13. #27
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Nice looking car. Suggests performance and personal taste while respecting the car. Like!
  14. #28
    Jun 2011
    wakefield mass
    50
    74
    I love my caddy can't wait to get everything done n hit the track n the road. Plusr I out caddy emblems in the SS have to make it a caddy part
  15. #29
    Classic L is offline Cadillac Owners Fanatic
    Automobile(s): 95 Concours / 88 Broughm D'el / 76 Coupe D'el
    Aug 2012
    Boston, MA USA
    111
    Welcome to the forum! I'm new here too, but have been owning Caddies since '88. I was scrolling through your pictures and said, "wait a minute! That's a MA lic plate." Then I looked and noticed you are from Wakefield. I live in Boston. Glad to know of someone close who has successfully done engine swaps too. Once I get my hands on another 85, I plan to swap out or rebuild the engine and big up the trans. More power would be fantastic, though I would like to keep as many bells and whistle in the navigator compartment as possible. In any case, thanks for sharing and the inspiration. Many years of happiness to you with your caddy and other cars. I'll keep my eye out when I'm on 95...
  16. #30
    chaztuna is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade
    Sep 2012
    phoenix
    75
    6
    Quote Originally Posted by MrHolland View Post
    Welcome to the forum. Lots of good info and people in here. Can't wait to see the pictures. You can use photobucket to host the pictures, its better that way. Enjoy your stay!!
    MrHolland..i am a newbee and need some help. would you be willing to send a note to me at my email charlie@scottbburg.com so we can talk "offline". thxs...chaztun a
  17. Remove Advertisements
