synthetic ac pump oil on 94 fwb?
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, synthetic ac pump oil on 94 fwb? in Past Cadillac Vehicle Discussion; hi guys. i'm replacing the condenser in my 94 fwb and i noticed a sticker on the dryer that says ...
    newside is offline Cadillac Owners Fanatic
    Automobile(s): 1994 fleetwood, 1979 deville, 1992 eldorado
    Mar 2010
    northern ny
    60
    139
    hi guys. i'm replacing the condenser in my 94 fwb and i noticed a sticker on the dryer that says to use synthetic oil in the ac pump or the system will be damaged. anyone have any experience with this? I'm havig a hard tim locating synthetic oil for the system. thanks
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: synthetic ac pump oil on 94 fwb?
    Has your system been converted to R134a? If so you want to use PAG oil. I doubt you will loose much oil if you are changing the condensor. Have you lost all of your refrigerent?
    Mar 2010
    northern ny
    60
    139
    thanks for responding dennis. the system was r-134a from the factory, and i have lost all the refrigerant do to a large leak in the condensor. on my dryer it says to use synthetic oil #12345923 or equivelent, i went to 2 auto supply stores and they don't have any. they actually haven't heard of it
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,983
    PAG oil is what it takes. All parts stores should have it.
    Mar 2010
    northern ny
    60
    139
    thanks Jay. i know they must have pag oil downtown, i think synthetic confused them. While i'm at it can the condensor be removed by removing the fans and then pushing the radiator back till i get enough clearance to pull the condensor? i see that the oil cooler and tranmission lines are hoses and might give me what i need to remove it, i'm afraid i'll tear up the fragile aluminium pipe when turning the nuts.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    Jay is correct.
    Have to ask for PAG oil.
  9. Remove Advertisements
