I have had it up to 90 MPH several times. What can I look at for top end? I have also been told that if I drill a hole in the cat. converter I will get a little better performance. Is this right? If yes how big of a hole and where?
Which motor do you have?
Top speed on an olds 307 is 120+ (but you'll have to find many many miles of flat straight ground for it to go that fast)
Personally (and I don't recommend this because these cars have 0 handling at triple digit speeds) I have done 110-115 in my caddy (once)
Top speed on a 350 is 130+, if the computer doesnt shut off your fuel supply first (105 or 110 IIRC). Truck computers will also go faster and make more power than a performance car (iroc camaro/ TA) computer. (Bump timing over 3k instead of retarding it and no fuel cutoff IIRC)
You aren't going to get much of a boost by drilling a hole in your cat (I assume you mean gutting it, which is illegal in some states). Removing your cat and installing a straight pipe might net you 2 hp...maybe....they aren't as restrictive as they were back in '74 when they came out. If you want to get more performance, try legitimate performance mods (CAI intake, headers/ dual exhaust, adjusting the carb/ bigger injectors on tbi etc.)
They do start going bad and gradually get worse. It isn't like a switch that goes from perfect to plugged. That is why I said "failing and getting plugged." Whatever, it was merely an observation....never mind.
Yes they do...I could watch the gas gauge go down very quickly when I went on the top speed run in my fwb (3 or so minute romp cost me 3 mpg over a full tank). It took forever to get over 100 once it got to 80 (0-100 is counted in minutes, not seconds.) Then theres the problem of the body sway shoving the car around even in sweeping curves.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
