Just got another Brougham, 88 5.0, need help with vacuum sensor - Page 2
Results 16 to 30 of 33
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Just got another Brougham, 88 5.0, need help with vacuum sensor in Past Cadillac Vehicle Discussion; Ah someone deleted it....
  1. #16
    Brough is offline Cadillac Owners Member
    Automobile(s): 1988 Brougham
    Aug 2012
    Maine
    47
    80
    Re: Just got another Brougham, 88 5.0, need help with vacuum sensor
  2. #17
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Quote Originally Posted by Brough View Post
    Looking for a diagram for the TV cable, I have a Hanes manual (POS) and a slightly better Chiltons.
    I'd toss those cheap manuals in the back of the bookcase and grab one from here. The are some great buys here.
    http://motors.shop.ebay.com/i.html?_...506.m270.l1313
  3. #18
    Aug 2012
    Maine
    47
    80
    Wow thanks Dennis! I found them on Helminc.com and searched ebay but must have used the wrong keywords. There's a service manual on there with a $4.99 bid!
    Anywho, found the vacuum line to the climate control, unhooked apparently by some dumba$$ as there was no sign of the associated hose anywhere, and hooked it to the mystery sensor in the pictures and VOILA! Climate control extraordinaire. A) People who are clueless should not try to work on cars, I know it's how we all learned, and yeah I probably screwed up a few as a kid too... B) I'm sure someone said it would cost a fortune for a climate control module and the possibility of dash removal.
    I adjusted the TV cable and got the thing to downshift, an improvement but need to see if the pedal is giving WOT at the butterfly because it doesn't feel like it.
  5. #19
    Aug 2012
    Maine
    47
    80
    Looking for a right rear quarter panel to bumper filler as well (preferrably in white), found these on ebay but with shipping I could buy new for $20 more.
    http://www.ebay.com/itm/110929641575...84.m1423.l2649
  6. #20
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    If the motor gives a loud WHOOOM sound when you stomp on it while doing under 40 mph, the secondaires are opening (307s are very loud when you floor it)
  7. #21
    Aug 2012
    Maine
    47
    80
    Thanks Kevin. I can open the secondaries if I WOT at the carb but don't think I notice them opening properly from the cabin. Can the main throttle cable be adjusted? I've seen the carb adjust procedures posted and have them in my "cheap" manuals as well, might have to wait until the weekend to find time. Slowly picking things off though, still feeling she's solid. I drove it ~100 miles yesterday and have a strange occasional vibration to track down not tire related. I'll probably pack the bearings, check the u-joints and change the rear end oil this weekend.
  8. #22
    Aug 2012
    Maine
    47
    80
    This keeps getting better. I did not test drive last night after hooking the climate control vacuum back up. This morning I had to move it to get my motorcycle out of the garage, and noticed a hiss when in gear. Searching this issue I believe I have found why the guy said the parking brake wouldn't release, must be a vacuum issue with the release mechanism! I haven't looked to see what the issue could be, the brake light has been on too just haven't had time to track it down.
  9. #23
    Dec 2010
    St. Louis, MO
    6,395
    Pull the parking brake release. It might be engaged a notch. (Not enough to engage the brake but enough to trigger the light)
    Edit: never mind. I forgot these don't have parking brake releases. Its supposed to release when you put it in gear.
  10. #24
    Aug 2012
    Maine
    47
    80
    Thanks Kevin. The hissing noise went away on it's own, and the brake and vacuum release are working properly. The cable needs to be tightened however as I have to lift the pedal with my foot to get the brake light to go out, but it does go out. SO looks like the vacuum and cabin issues are squared away, back to it being nutless. The secondaries only crack if I pin the throttle pulley, and I'm not convinced I'm getting WOT with the pedal so a couple things to work on there regarding power. My CE light is back too so I need to read the codes. The kid I bought it from said he had the codes read and the O2 sensor came back, however I don't know what to believe from him because it appears he messed up a bunch of stuff he didn't tell me about.
  11. #25
    Dec 2010
    St. Louis, MO
    6,395
    Do you know how to pull codes?
  12. #26
    Aug 2012
    Maine
    47
    80
    Assuming it's just like every other similar vintage GM vehicle with a diag connector jumper and CE flashes. I can google the codes.
  13. #27
    Aug 2012
    Maine
    47
    80
    Holy crap, never got so many codes. Hoping some of them are archival and will go away once I reset. 12, 15, 21, 34, 44, 45, the last two are a contradiction, Lean and rich O2 sensor. The kid did say he was amazed how many sensors were on the thing, he might have thrown codes while he was messing with it, hoping some go away with a reset.
  14. #28
    Aug 2012
    Maine
    47
    80
    Reset and thorough flogging test drive and down to first three codes. Experience tells me if more than one sensor is throwing codes look for electrical issues first, test sensors second. It did seem to have more nut after resetting the computer but it might have been mental. I don't know what the computer could be messing with on a carb model anyway (besides timing, which could mean everything) but what do I know?
  15. #29
    Dec 2010
    St. Louis, MO
    6,395
    The computer controls timing and fuel mixture.
    You might have a vacuum leak or improperly routed vacuum lines (especially since the previous owner was messing with (up) the engine bay.)
  16. #30
    Aug 2012
    Maine
    47
    80
    Changed out a bunch of vacuum lines and learned what the heat riser valve does, I still don't have any heartache over eliminating it. I did wire it backwards (closed) which couldn't have been helping (duh), turns out they fail open. If I ever have the exhasut out I might replace it and make it right. Douched the top of the motor pretty good. Going to pull the codes again and du some diagnostic on the asociated sensors, after I verify alll the connectors are tight on the ECM.
  17. Remove Advertisements
