Car won't hold charge
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By The Ape Man
1985-1996 Fleetwood and Brougham Forum Discussion, Car won't hold charge in Past Cadillac Vehicle Discussion; For a couple days my car battery was dead every time I wanted to go somewhere. I would charge it ...
    maxjacks40 is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Brougham
    Mar 2011
    24
    10
    For a couple days my car battery was dead every time I wanted to go somewhere. I would charge it and then the next time it would be dead again. So I took it to my auto shop and they tested it and said that the alternator wasn't charging the battery. It was at 12 volts originally and when I started the car it didn't go up at all. So I pulled out the alternator and took it to the store and they ran it through their test and said it actually passed all of their tests. So I put the alternator back in and bought a new battery.
    It started right up and I was driving for probably 10 mins before the battery completely died on me. So I thought there still has to be something wrong with this damn alternator. I took it out on the spot and got picked up, bought a new alternator and intalled it. Same problem. Brand new battery and alternator and it still will not hold a charge. What else could it be? The battery terminals are clean and I am positive that everything was installed properly. Getting ver annoyed with this car
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: Car won't hold charge
    If the battery is new and the alternator is new and good and it is still not charging it has to be a connection or a bad wire...I would first look at the plug that plugs into the alt. and check or change the alt. output wire that goes to the batt. this is , most of the time, a heavy red wire.. I think they are a number 10 wire.. If this wire burns out =no charge.... The plug that powers the alt, if thats not making a good conection=no charge.... When you find it you will say Look there is that SOB...
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Measure the voltage across the battery terminals with the car off, and on. Post the numbers.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    The car just died out of nowhere after 10 minutes while you were driving? It's probably something else causing the problem like a bad connection somewhere because unless both the battery and the alternator die at the same time it'll keep running.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    A brand new battery, even with no charge from the alternator, would last more than 10 minutes. It sounds like a connection (like brougham) suggested - and a big one at that. Make sure the ground is securely attached to the block, and the positive connections are securely attached to the starter and alternator. Also makes sure that the terminals are securely connected to the battery cable.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Just throwing this out there.
    You are dealing with your 90 Brougham with stock set up right?
    if you're not and talking about an older car then the voltage regulator would be separate from the alternator and highly suspect.
    Mar 2011
    24
    10
    Going to be checking the wires today. If I remember correctly the plug goung into the alternator looked a questionable but it alsways ran fine before and I haven't done anything to it. Before I bought the new battery I tested the voltage when the car was off was 12 and it did not go up when the car was turned on, which is what led me to believe it was a alternator in the first place. Intersesting about the voltage regulator, could that cause something like what I am dealing with? I would jump the car and it would run with some pressure on the gas but only when I was in park. Usually when I shifted into drive it died out.
    Jan 2011
    Southern Ontario
    934
    Voltage regulators became internal to the alternator sometime mid to late 70's. So if it's your 90 that your having the problems with, the voltage regulator would have been replaced when you replaced the alternator.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    I'm not sure on a '90 but a few years older would give the same problem is the charging lamp in the dash were burned out.
    The lamp was in series with the regulator.
    csbuckn and csbuckn like this.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by The Ape Man View Post
    My '87 Buick was that way...not sure how many years after they continued that circuitry.
  13. Remove Advertisements
