1989 Brougham AC compressor ON-OFF-ON-OFF-ON-OFF cycling
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, 1989 Brougham AC compressor ON-OFF-ON-OFF-ON-OFF cycling in Past Cadillac Vehicle Discussion; Hi All! A friend of mine has brought his AC system "back to life". He replaced a lot of things, ...
    tibi500cid's Avatar
    tibi500cid is offline Cadillac Owners Fanatic
    Automobile(s): 1976 Cadillac Fleetwood Brougham and 1996 DeVille
    Dec 2005
    Budapest Hungary/European Unio
    43
    120
    Hi All!
    A friend of mine has brought his AC system "back to life". He replaced a lot of things, let the compressor and other things rebuilt, and installed. Pressure is OK in the system, no loss. But now (mainly when idling, but not only at idle) very often he has the following symptom: the AC compressor switches on for about 1 sec then switches on for about 1 sec and this goes on and on...
    I couldn't find anything in the Shop Manual for this condition. Anyone has some experience with this kind of problem?
    Thanks!
    Feb 2003
    california
    69
    6,640
    Re: 1989 Brougham AC compressor ON-OFF-ON-OFF-ON-OFF cycling
    If you mean "off then on" and you know for sure its full of freon, I would suspect compressor clutch to coil gap is too wide. When its too wide, voltage alone cannt hold it engaged. The gap is adjusted by shims added or taken off the compressor shaft.
    tibi500cid's Avatar
    Dec 2005
    43
    120
    Thanks for the tip, will try out ASAP!
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,902
    The charge is low. It is that simple.
  7. Remove Advertisements
