Spark plugs for the 78 Coupe Deville 7 liter engine
Results 1 to 13 of 13
Like Tree2Likes
  • 3 Post By jayoldschool
1985-1996 Fleetwood and Brougham Forum Discussion, Spark plugs for the 78 Coupe Deville 7 liter engine in Past Cadillac Vehicle Discussion; Autozone recommended platinum spark plugs, so I bought and installed them. The car was already hard to start when cold, ...
    ruttrow's Avatar
    ruttrow is offline Cadillac Owners Member
    Automobile(s): 78 Coupe Deville
    Jan 2012
    Central North Carolina
    52
    63
    Autozone recommended platinum spark plugs, so I bought and installed them. The car was already hard to start when cold, but now it is worse. I have to crank the peddle about 6 - 10 times, and/or wait after pumping the pedal. And the motor is still a little rough at idle.
    A mechanic told me I have the wrong plugs. Platinum is why the car is running rough.
    Please let me know what you know if I need to pull the plugs and put copper ones in their place.
    Thanks
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Spark plugs for the 78 Coupe Deville 7 liter engine
    I am a fan of regular AC Delco plugs in GM cars.
    pompste, 1980coupe and 1980coupe like this.
    ruttrow's Avatar
    Jan 2012
    52
    63
    It was a real pain installing the plugs near the firewall on each side. The other six were not bad. If I thought it would make a significant difference I would take out the platinum.
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Has she had a tune up lately?? Maybe a week coil or out of timing!! Definately use the old school plugs, in your case R45NSX.
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Check the pickup coil inside the distributor. Not the coil in the distributor cap but the coil that is in the distributor housing. The wires I think are green and yellow. I've had them break on me a couple of times. The coil is probably weak and thats why it runs like crap with the platinums.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Check the gap on the plugs. I know people who take plugs out of the box and install them without checking the gap. Gaps can change from shipping, or the factory sets the gap for a specific application, they just happen to fit the criteria for your engine.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Quote Originally Posted by jayoldschool View Post
    X2,
    I was recommended the exact ones for my 78 and 80 coupe and I said no. Give me the Auto Lites or AC Delco ones, which the 78 got Auto Lites and I got the AC Delco for my 80.
    Gap on both is .60
    GeneLaw1 is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Coupe Deville, 1989 Brougham, 1984 Mercury Cougar,
    Sep 2009
    Atlanta, Georgia
    31
    201
    I have used the AC Delco platinum in both my Caddies without issue.....your problem may lie else where in the ignition system.
    ruttrow's Avatar
    Jan 2012
    52
    63
    Thanks for the replies! I heard I need to check two things next. One, the carb fuel float level, and two, the choke. I will
    take her back to my mechanic at the end of the month to look at these. I do not know how to check these things. That stuff
    is too deep for me (But you guys could do this with your eyes closed I bet!)
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It sounds like you need a simple choke adjustment; 5-10 minute job. Platinum plugs won't hurt anything. I have used Bosch Platinums in all my vehicles for 15 years with no problems yet The Platimuns in my Seville are about 15 years old but only 40k miles. I can't get AC's to last 2 years and I'm too lazy to replace them all the time.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    What about the spark plug wires? Have they been replaced lately?
    Eldo81 is offline Cadillac Owners Member
    Automobile(s): 78 Seville, 81 Eldorado
    Oct 2016
    1
    Hello, if you are working on a 78 Seville, your engine size could be wrong, in that year there were only two type engines in the Seville 350 Olds gas and 350 Olds diesel.
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Mr
    Could need a choke adjustment, as mentioned.
    My '78 Deville had a rough cold idle last year until I adjusted it--minor butterfly adjustment.
    I just replace needed parts with what the engine was designed with---all ac/delco whenever possible.
  16. Remove Advertisements
