digital odometer
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, digital odometer in Past Cadillac Vehicle Discussion; I have read some other threads that have been all over the place with problems with the digital dash but ...
    maxjacks40 is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Brougham
    Mar 2011
    24
    10
    digital odometer
    I have read some other threads that have been all over the place with problems with the digital dash but I have a 90 Brougham and just the odometer glitches; everything else works great. Sometimes its right on with the mileage which is only around 60,000 but alot of times it starts going crazy with a whole bunch of higher numbers, other times it just reads ERROR. I want to sell the car and i figured it would probably be good to figure this out before then. Any tips/suggestions?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,605
    Re: digital odometer
    Its gone bad. I havent seen any type of repair available for these and they go out pretty often. I took a bad one apart and it was full of dust but I could see anything wrong with it. Might try taking it to a small electronics shop with a wiring diagram.
    Mark 78 Coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 1978 Coupe De Ville, 1993 Fleetwood
    Sep 2011
    Cleveland/Ft. Myers Beach FL.
    58
    527
    Many years ago I had a 90 with the exact same problem. A local shop made an extremely simple repair that, in my case, fixed the problem. On the transmission, the speedo cable attaches on the side. He said he simply took the cable off ( it unscrews like a light bulb) and cleaned and lubricated the cable where it enters the transmission. He told me he had fixed several cars with that exact problem that way and it worked. Keep in mind this was maybe 10 years ago, so maybe your problem is different, but it is sure a cheap and easy first step. Good luck.
  5. #4
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,425
    The problem is in the digital dash itself like csbuckn said. There are a few places around that fix them and the dealer can do it too but the price isn't worth it.
  6. Remove Advertisements
