Help hooking a stero system up
Results 1 to 14 of 14
1985-1996 Fleetwood and Brougham Forum Discussion, Help hooking a stero system up in Past Cadillac Vehicle Discussion; I have a 93 Fleetwood Brougham and I need a little help. I bought a new stero 4-5 1/2, 4-6/9 ...
    hailhopes is offline Cadillac Owners Member
    Automobile(s): 2015 Cadillac CTS-V 6.2
    Mar 2012
    Houston
    40
    42
    I have a 93 Fleetwood Brougham and I need a little help. I bought a new stero 4-5 1/2, 4-6/9 and amp. Wondering how to set the it up without using the old amp that comes with the car. Do I have to run new speaker wire to the back of the head unit. Also anyone have any idea where I could run my power and ground cables from the battery to the back? Want to use radio without the use of the factory amp
    outsider is online now Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,198
    Re: Help hooking a stero system up
    not sure if the 93 has the external amp in the trunk like my 95 but I had to buy a bypass harness that ran from the amp in the trunk up to the front of the car.
    see my thread from my install here: http://www.cadillacforums.com/forums...o-install.html
    Mar 2012
    Houston
    40
    42
    yea its in the back so the new harness hooks into the external amp in the back but how do u hook it up with the new amp i bought? or does the RCA wires do that
    Sep 2009
    33
    4,198
    usually the amp would hook up to the RCA wires when I've installed amps in the past. They were for subwoofers, though, but most amps I've seen are the same.
    they need power from battery, ground, and then RCA hook up from head unit.
    from there, you would need to connect the speaker wire from the speakers to the amp.
    hope that helps.
    Mar 2012
    Houston
    40
    42
    Ok so do I hook that speaker wire from the head unit to the back or isnt that what the RCA jacks do or indviually hook the speaker wire from speaker to amp
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,619
    How many RCA outputs are on the deck and how many inputs are on the amp?
    Mar 2012
    Houston
    40
    42
    6 out of my head unit and a 4 channel amp. Don't I have to take the factory amp out and re-hook everything to my new amp?
    Jan 2008
    Minneapolis
    5,619
    You need to run front RCAs of the deck to the front RCAs of the amp, rear RCAs of deck to rear RCAs of the amp. You can then run your own speaker wire to each speaker, or, If you mount the amp in the trunk, you can use the wires that are already going to the speakers and put them into the new amp. When you replace the speakers, pay attention to the color of the wires that are hooked up to the speakers so you know which ones to use off the stock amp wiring. You dont have to take the stock amp out, just let it sit incase you take the aftermarket stuff out.
    Mar 2012
    Houston
    40
    42
    so i cut the wires off the turner in the trunk then hook them up together running my speaker wire to the new amp
    marz2684's Avatar
    marz2684 is offline Cadillac Owners Member
    Feb 2012
    35
    Is the wiring different from the 96 fwb i have the service manual and can take pics of wiring diagrams and plug explanations
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    33
    1,152
    Yall have this guy all confused
    you run a power, ground, remote and accessory power wire off of the head unit to the rear factory amp...if you are going to use an aftermarket amplifier for the highs or subs you need to run rca's off the headunit to wherever you mount the amp...if you are not going to use an aftermarket amp and just want to use factory sound then you have to run speaker wire for all 4 speaker outputs on the headunit to the factory amp in the trunk
    dont cut any wires in the trunk, use the required harness and plug it into the factory amp
    Mar 2012
    Houston
    40
    42
    Ok so use the wiring harness but from my new amp dont I have to run speaker wire from all the speakers in my car. I adding 8 speakers 4- 5 1/4 and 4- 6/9s. Isnt that box in the back just a tuner like a brain and isnt an amp?
    Jan 2008
    Minneapolis
    5,619
    I had it right. Nola, he's using the amp for the highs. Run RCAs from the deck to the amp and run speaker wire from the amp to each speaker. Another option I gave him was to cut the wire from the factory amp wiring that goes to each speaker and plug it into the new amp. But I see that you're running 8 speakers now, just run new speaker wire to each from the amp.
  16. #14
    Mar 2012
    Houston
    40
    42
    thats what im thinking is just cut the speaker wire from that amp then plug that into my amp from there. I was going to run my highs and mids parallel anyways
  17. Remove Advertisements
