No start on 84 CDV...wondering if anybody had any ideas
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, No start on 84 CDV...wondering if anybody had any ideas in Past Cadillac Vehicle Discussion; Ive recently been working on my grandfather's 84 coupe. It started giving me problems, so I started replacing parts. Started ...
    fslay is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Coupe DeVille
    Jan 2005
    Mississippi
    100
    Ive recently been working on my grandfather's 84 coupe. It started giving me problems, so I started replacing parts. Started out no fuel pressure, so I replaced the pump and now it holds 9 psi pressure. I've also replaced the cap, rotor, coil, fuel filter, vacuum lines and other odds and ends that were all marked "Delco Remy" so i figure they're probably all original parts.
    Anyway, I know I got steady fuel pressure up to the schrader test valve. The car will spin over when i turn the key, but won't actually crank up so I can drive it. It acts almost like I got a bad connection somewhere. Where would any of you with experience with these cars recommend I start? I suspect its something minor. Should I just get out the voltmeter or what? I sure appreciate any help.
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: No start on 84 CDV...wondering if anybody had any ideas
    Did you get the rotor seated in the right location?? Coil connections all in the right place.Grounds??
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,180
    Check if you're getting spark. You can do this by pulling one of the sparkplug wires and holding it near some metal while someone cranks. You should see it arching. I think it has to be the #1 plug but not sure.
    If no sparks jump then you know it's in your distributor or the plug wires.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    The fastest way I have of check for spark is to use a timing light. You put the detector around each wire one at a time to see if it lights up and that all are sparking (and you can also check the timing at the same time too). It won't tell you if the spark is strong or not.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Any fuel spray from the throttle body injectors when cranking?
    Jan 2005
    Mississippi
    100
    Ok i did some checking and the new ignition coil I bought apparently has a coat of black paint on the surface of the metal plates...all over the surface. Does this pose a grounding problem? I was just wondering if I should scrape the paint off the plates because that surface comes into contact with a ground wire and a small strap
    Feb 2003
    california
    69
    6,680
    If you have fuel pressure and spark it should start. I would verify the timing gear isn't stripped. Start with the basics, run a compression test. As mentioned above, get a timing light and see where the timing marks are as you crank it over.
  10. Remove Advertisements
