installing power steering pump pulley on HT-4100
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, installing power steering pump pulley on HT-4100 in Past Cadillac Vehicle Discussion; I just bought a new power steering pump and new power steering pump pulley, so no rust or other buildup. ...
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    I just bought a new power steering pump and new power steering pump pulley, so no rust or other buildup. This is the press on type pulley that requires a bolt, nut, and washer to put it place. I put anti-seize on the pump shaft. I have a ~9 inch long crescent wrench that I'm using to tighten the nut that pushes the pulley. I'm using most of my strength to turn the nut and I believe I have streched the bolt slightly, but the pulley is still almost 1/2 inch from being all the way on.
    Does it typically take this much force to put it in?
    I had used a little heat to try and help it on
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Re: installing power steering pump pulley on HT-4100
    It usually doesnt take that much pressure but I suppose some will. I've never had any that took more then some elbow grease to put it on. I have stripped a couple bolts before, though.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,984
    How about putting the pulley in the oven at a low heat for a couple of hours, then putting it on with an impact?
    Jan 2011
    Southern Ontario
    934
    Quote Originally Posted by jayoldschool View Post
    Interesting idea, but I'm not sure how to execute it. Since there's a bolt threaded into the pump shaft, I'm not sure how to get an impact on the nut.
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    Hi Jon!
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    A good hardned washer applies pressure evenly. Maybe something is a bit off.
    redbull749 is offline Cadillac Owners Member
    Automobile(s): 1982, 1983, 1984 Cadillac Coupe DeVille
    May 2014
    1
    Hi,
    I need to reinstall the steering pump pulley. The bolt that came with the pulley remover does not fit the shaft. Do you know what size the bolt is?
    Jan 2011
    Southern Ontario
    934
    Perhaps it's the wrong pulley remover? I've returned the one I borrowed so I can't help you. But I did discover that there is are more then one design styles for the plate you used to install the pulley. One (the one I had) is just the plate that presses up, this means there is lots of friction between the pulley and the nut. The second style has a bearing between the pulley and the nut and it's much easier/nicer to use.
    I never did get the pulley all the way on the pump shaft, but it hasn't given me any problems with wearing or throwing belts.
  11. Remove Advertisements
